Alternator sp sensor fuse keeps blowing 7.5Fuse (Honda Civic LX 98)
Old 10-21-2011, 09:22 AM
Aaron Cayabyab's Avatar
Default Alternator sp sensor fuse keeps blowing 7.5Fuse (Honda Civic LX 98)
My honda civic lx 98 keeps dying and alternator fuse (7.5) keeps blowing nothing else blows besides that one fuse what im thinking is a short (but where should i look) or a new Fuse Box?Any input will be helpful!
1 Tip:Check Engine Light Is On
2 Tip:Lights Flicking **** Dying Like The Radio
Old 10-21-2011, 10:35 AM
Former User's Avatar
Default Re: Alternator sp sensor fuse keeps blowing 7.5Fuse (Honda Civic LX 98)
Click on the fuse 15 TSB in my signature.
Old 10-23-2011, 10:27 PM
Before i do this i had a short the other day when installing my amp and burnt the wires (remote wire that connects to amp-cigarette lighter) but all the other fuses was good and in fact the fuse didn't blow out it self did i damage the Fuse Box or should i still follow the direction about fuse 15?
Buy a new fuse box?
Old 10-24-2011, 12:13 PM
Check, tape, and cover the wires near the C115 connector as detailed in the TSB.
Old 10-24-2011, 02:04 PM
So the short i had couldn't do anything with the fusebox being broken? & Ill check the C115 Connector ASAP
Old 10-24-2011, 03:14 PM
motegicivic's Avatar
Buy a new fuse box?
Whoa, how did you wire the amp???
Did you go the battery direct?
Did you fuse the power wire about 16 inches from the battery?
Old 10-24-2011, 03:37 PM
Access the C115 connector and wires from below the car.
Old 10-25-2011, 01:34 AM
Nope i had a wiring kit everything was installed fine until i got a new sub and the remote wire kept blowing out my fuses!
Old 10-25-2011, 01:35 AM
I did this today and seems to work now wired up all the wires and new fuse!
Old 10-25-2011, 04:34 AM
When you looked at the wires, were any broken or insulation torn?
Old 10-25-2011, 12:28 PM
Nope! the electrical tape was just worn out so i took it off and applied new one
Old 04-13-2014, 11:06 AM
Dizzle69's Avatar
Old 04-13-2014, 11:08 AM
Dizzle69's Avatar
Just had same problem and it was the down stream 02 sensor plug to the car hitting body had split wire shorting out
Old 01-11-2019, 04:23 AM
1SIKSI's Avatar
👍🏽i had the same issue it was the O2 sensor i guess i shorted a wire when i was messing with my cat.
Crocky
04-19-2017 11:03 AM
monsterCHILD
01-06-2011 04:28 PM
CheddarPopcorn
06-30-2009 10:53 AM
Sic_DA_Nine
01-08-2007 09:54 AM
Cyrus4g63
10-09-2006 08:40 PM
Quick Reply: Alternator sp sensor fuse keeps blowing 7.5Fuse (Honda Civic LX 98)
