Alternatives to factory wheels (guide)
Old 04-27-2003, 07:04 AM
Inigo Montoya's Avatar
Default Alternatives to factory wheels (guide)
I know I saw a topic in the last couple of months asking what other types of factory wheels will fit our Honda's. I ran across a site today that may help us out so I wanted to post the information here. (note- some information may be incorrect, they listed the bolt pattern for a civic as 5x100, but the rest of the info has been correct) Here is the site I was getting this off of, also, some of the sizes listed may not be sold as factory wheels, the guide is one for after-market applications, I was just looking for the spacing, hub size, and offset.
http://www.xtremetna.com/wheel...e.htm
Here are the specs for our factory wheels-
14x6 4x100 mm +35 mm 56.1 195/60x14
15x6.5 4x100 mm +35 mm 56.1 205/50x15
Now, I have found a few other manufactures that have the same bolt pattern, but the hub needs to be larger, in theory, you should be able to bore them out to fit on the Honda hub.
Disclaimer- I have not personally tried this, so if it does not work, I apologize and please post the information here for others to use.
AUDI - VW
Audi 4000S (80-84)
Cabriolet (92-94)
Cabriolet III (95 +)
Corrado G60 (89-92)
Fox (All) (87-93)
Golf II & III (85 +)
Jetta I (81-84)
Jetta II & III (85 +)
Passat 4 Cyl (90 +)
Rabbit (76-81)
Rabbit Conv. (80-91)
Scirrocco (76-89)
The listed information is
14x6 4x100 mm +35 mm 57.1 185/60x14
15x6.5 4x100 mm +40 mm 57.1 195/50x15
15x7 4x100 mm +40 mm 57.1 195/50x15
16x7 4x100 mm +40 mm 57.1 205/45x16
So you can see the listed hub here is larger. But I have heard of people using older VW rims on a Honda, if anyone can confirm this that would be great.
BMW
318 (84-91)
325 E-30 (84-91)
Wheel Size Bolt Pattern Bkside Off Set Hub Bore Suggested Tire Size
15x7 4x100 mm +20 mm 57.1 205/55x15
16x7 4x100 mm +20 mm 57.1 205/50x16
16x7.5 4x100 mm +20 mm 57.1 205/50x16
Not sure on these, same pattern but the offset is really off, but that may also be due to how BMW lists their offset, worth a shot if anyone has some lying around. Also same goes for the hub size, same as the VW though.
Ford/Lincoln/Mercury
Ford Escort (91 +)
Mercury Tracer (91 +)
13x5.5 4x100 mm +38 mm 54.1 175/70x13
14x6 4x100 mm +35 mm 54.1 185/60x14
15x6.5 4x100 mm +40 mm 54.1 195/50x15
The spacing and the pattern is the same, but the hub is much smaller, not sure if you could make these work. The factory wheels might not like being bored out that much to fit our hubs.
Isuzu
Impulse (91-92)
Stylus (91-92)
14x6 4x100 mm +35 mm 56.6 195/60x14
15x6.5 4x100 mm +40 mm 56.6 205/50x15
15x7 4x100 mm +40 mm 56.6 205/50x15
The hub is just larger on these, not sure if they make stuff to change the hub size to smaller
Kia
Sephia (94 +)
13x5.5 4x100 mm +38 mm 56.1 165/70x13
14x6 4x100 mm +35 mm 56.1 185/60x14
14x7 4x100 mm +35 mm 56.1 185/60x14
these would work with no modification to the hub, might be good for those looking for steelies? Otherwise rock those factory kia rims
Mazda
323 (90 +)
GS (92 +)
Miata (90 +)
MX3 (92 +)
Protege (90 +)
15x6.5 4x100 mm +35 mm 54.1 195/50x15
15x7 4x100 mm +40 mm 54.1 195/50x15
16x7 4x100 mm +40 mm 54.1 205/45x16
Another candidate for boring out. I have seen pics of miata wheels on a Honda, so I know this should work.
Mitsubishi
Mirage (93 +)
13x5.5 4x100 mm +38 mm 56.1 175/70x13
15x6.5 4x100 mm +35 mm 56.1 195/50x15
15x7 4x100 mm +40 mm 56.1 195/50x15
Another ones with the same size hub, should work in theory.
Nissan
200SX (95 +)
NX1600 (91-93)
NX2000 (91-93)
Pulsar (87-90)
Sentra All (86 +)
13x5.5 4x100 mm +38 mm 59.1 175/70x13
14x6 4x100 mm +35 mm 59.1 185/65x14
15x6.5 4x100 mm +35 mm 59.1 195/50x15
15x7 4x100 mm +40 mm 59.1 195/50x15
Larger hub, so not sure if this would work.
Saturn
SC Coupe (91 +)
SL 4DR (91 +)
SW Wagon (93 +)
14x6 4x100 mm +35 mm 57.1 185/70x14
15x6.5 4x100 mm +35 mm 57.1 195/60x15
15x7 4x100 mm +35 mm 57.1 195/60x15
Again, a larger hub.
Suzuki
Esteem (95 +)
Smaller hub, bore the baby out.
Toyota
Celica (86-91)
Corolla (89 +)
FX16 (87-89)
MR2 (86-90)
Paseo (92 +)
Tercel (89 +)
Again, smaller hub, anyone want to try?
That looks like all this site had listed. I hope that some of you find this information interesting. I personally have more cars to look at now when trying to find replacement wheels.
Edited and Added-
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">http://www.wheelweights.net
His list does contain some factory wheels. Hope this helps.
I took a look, the information is good to have.
Comments and corrections welcomed.
Modified by Inigo Montoya at 9:52 PM 4/30/2003
Modified by Inigo Montoya at 9:53 PM 4/30/2003
Old 04-27-2003, 09:00 AM
JasonBlackEJ1's Avatar
Default Re: Alternatives to factory wheels (Inigo Montoya)
i saw a guy driving a white honda and he had some white lexus wheels on his. they looked pretty badass, too.
Old 04-27-2003, 09:35 AM
ThisLittleSleepeR's Avatar
Default Re: Alternatives to factory wheels (JasonBlackEJ1)
nice post
Old 04-27-2003, 10:24 AM
Default Re: Alternatives to factory wheels (ThisLittleSleepeR)
ttt
Old 04-27-2003, 10:27 AM
black2kcivic's Avatar
Thanks!
I personally want to find those mazda wheels that look like hx rims.
Old 04-27-2003, 05:16 PM
Default Re: Alternatives to factory wheels (black2kcivic)
Are you talking about the mazda millennia wheels (9 lbs, pretty sweet!)? Those are going to be 5x114, good for people with type r conversions. If you know of any of the above that look like HX rims, please tell the rest of us
Old 04-27-2003, 06:07 PM
92CIVICCX's Avatar
iwould also be interested.. cause im about to get some hx wheels pretty soon
Old 04-27-2003, 06:58 PM
mixmastabob's Avatar
Nice post. Now I KNOW I can pimp my friend's old 1982 14in Scirrocco wheels!
Old 04-28-2003, 02:25 PM
up cause lots are looking, few are bumping it back up for others
Old 04-28-2003, 03:32 PM
RSZero1's Avatar
i've tried the miata's, nissan sentra, bmw(old school), and paseo. those all DO work, same bolt up etc...bump for everyone else...
Old 04-29-2003, 01:28 PM
Default Re: Alternatives to factory wheels (RSZero1)
Thanks for answers on those, would you guys mind posting what sizes you had?
I think that would also help folks out.
Old 04-29-2003, 02:08 PM
Mr. Thunderlips's Avatar
I know a guy that used to run older Jetta wheels on a 1998 Civic coupe.
Old 04-29-2003, 02:56 PM
Mt3c's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Inigo Montoya &raquo;</TD></TR><TR><TD CLASS="quote">
Toyota
Celica (86-91)
Corolla (89 +)
FX16 (87-89)
MR2 (86-90)
Paseo (92 +)
Tercel (89 +)
i've tried 2000 Toyota MR2 Sypder rims on a civic. Doesn't fit without boring out the hub. Rims were 15x6 and 15x6.5, five spoke design.
BTW, good info.
Old 04-29-2003, 07:08 PM
Thirty-Nine's Avatar
I might be way off here, but would any of those need a hubcentric adapter? I really like the Miata rims, too, but I thought I heard of some people saying that they shake because they wern't hubcentric ...
Old 04-29-2003, 07:24 PM
Default Re: Alternatives to factory wheels (Sushiboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sushiboy &raquo;</TD></TR><TR><TD CLASS="quote">I might be way off here, but would any of those need a hubcentric adapter? I really like the Miata rims, too, but I thought I heard of some people saying that they shake because they wern't hubcentric ... </TD></TR></TABLE>
Persobally I am not sure, I have seen pic online of people with miata wheels, but nothing about neediong a hubcentric adaptor. I posted this over in the autocrossing forum, maybe one of those guys can help us out.
Old 04-29-2003, 07:27 PM
There is a thread about Miata wheels I just found:
https://honda-tech.com/zerothread?id=101798
Looks like some machining is needed.
Old 04-29-2003, 08:06 PM
bad 2 the B-ONE ej1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blk2kcivic &raquo;</TD></TR><TR><TD CLASS="quote">(original post)---&gt;I personally want to find those mazda wheels that look like hx rims</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Inigo Montoya &raquo;</TD></TR><TR><TD CLASS="quote">Are you talking about the mazda millennia wheels (9 lbs, pretty sweet!)? Those are going to be 5x114, good for people with type r conversions. If you know of any of the above that look like HX rims, please tell the rest of us </TD></TR></TABLE>
i think hes talking abot the ones that look like the wantanabe's alot of the ae86 use...
Old 04-29-2003, 10:41 PM
PatrickGSR94's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Inigo Montoya &raquo;</TD></TR><TR><TD CLASS="quote">I know I saw a topic in the last couple of months asking what other types of factory wheels will fit our Honda's. I ran across a site today that may help us out so I wanted to post the information here. (note- some information may be incorrect, they listed the bolt pattern for a civic as 5x100, but the rest of the info has been correct) Here is the site I was getting this off of, also, some of the sizes listed may not be sold as factory wheels, the guide is one for after-market applications, I was just looking for the spacing, hub size, and offset.
Comments and corrections welcomed.</TD></TR></TABLE>
Factory 15" Civic and Integra wheels are 15x6, just to clarify.
Old 04-30-2003, 08:48 AM
rpr
rpr's Avatar
Kia
Sephia (94 +)
Where did you find the information on Kia having a 14x7? I have searched high and low for this information, and have found the largest stock Kia Sephia wheel to be 14x6. If you have a definitive source on that one I'd be a very happy man (as I'm sure would others!)
edit: ah, I see your source. I found that site in my search, didn't realize it was your source. oops. that is the ONLY site that says 14x7, I think they are talking about wheels that COULD fit, as opposed to stock wheel sizes.
Thanks
Old 04-30-2003, 02:44 PM
Default Re: Alternatives to factory wheels (rpr)
Yeah, the site is not good for listing actual factory wheels sizes. If some of you out there know what actual figures are, I would be glad to update any information at the top of the page.
oh, and about the miata wheels, i do realize that machining is necessary. if you look at some of the comments i posted, some of the others may have to be machined as well.
Old 05-01-2003, 10:54 AM
wakaru's Avatar
Chrysler - All four-lug Omni/Horizon variants. 13, 14 and 15" sizes. Not sure of widths or offsets.
Old 05-01-2003, 11:08 AM
CivHatchH22's Avatar
Default Re: Alternatives to factory wheels (wakaru)
How about some of these bad boys!
Old 05-01-2003, 11:10 AM
TrboInteg's Avatar
Good post. Very informative!
Old 08-22-2003, 03:25 PM
Mt3c's Avatar
adding some info...
2003 Mini Cooper base model 7 hole wheels.
15x5.5 +45 offset.
Hubbore = don't know exact, but almost identical to Hondas.
weight= haven't gotten a change too yet, but feel lighter then rota c8s
more pics
the other Mini Cooper wheels should fit no problem
JmR2004Acura
12-28-2017 10:30 AM
ragnaroek
11-07-2006 01:41 PM
ramrod
04-09-2006 05:59 PM
superpilun
13
02-21-2006 08:04 AM
p0pe
10-28-2003 04:26 PM
Quick Reply: Alternatives to factory wheels (guide)
