all you vtec guys...
#27
#28
Re: all you vtec guys...
here is a pin out on the ecu side. You have to wire some pins to A4(vtec solenoid) and D6(vtec pressure switch) Those are the 2 you have to worry about. Go to a local junk yard or use you old dx harness and cut some pins out it. And some wire to them so they can reach the ecu and VIOLA.....MAD VTEC YO!
#29
they dont. He is just pointing out where they go. Since you have the z6 harness all you have to do is run some wires from those holes(on cabin side), according to which one is which in each whole. And run them to the correct ecu pins. Which i provided you with on the other pic. That pic is a refference for you to know which wire is which so when you wire them to ecu you dont mix them up.
#30
ok cool. so the spots for those wires are there then? sweet ****. ok. honestly what kind of diff do you think vtec wil make? i understand the power band is longer and vtec crossover isnt too noticable... but was the swap worth it?
#32
those pinouts work on the p08 for now correcet? im not sure how long it will be till i get my hands on a mt p28
#39
#40
If this is a p08, and the p08 really does have a 1 wire o2, then why does this ecu show for a heated o2 sensor?
I mean, im sure sure its all the same ****. Dont get me wrong. Im just interested to know if the p08 really only is a 1 wire.
#41
That isn't a P08, its just a general ECU pinout diagram. Shows everything to add wiring for any swap. I.E. If you're just adding VTEC ignore the rest. Or B series in a non-VTEC car, add VTEC and knock sensor. GSR swap, add IAB.
#43
hi guyes i need p08 pin out my engine f20b obd2 i m converted for p08 obd 1 some problem came here rpm not stable please help me
InfamousRS
05-21-2002 04:09 PM
