Adjusting the rear brakes- drum
Old 06-16-2008, 05:12 PM
tortis's Avatar
Default Adjusting the rear brakes- drum
i replaced my shoes a while back, don't drive the car much, i know , it is a shame, but how do i adjust the rear shoes. the manual says the adjustment is on the inside of the lower control arm.
i took the rubber grommet off and could not feel the adjuster.
tried the backing up and applying the brake routine. didn't do much.
adjusted the emergency brake and that helped.
thanks for any help. 95 civic.
Old 06-16-2008, 05:18 PM
pdiggitydogg's Avatar
Self-adjusting never works.
There is a star nut inside where the rubber grommet is...grab a light and you'll see it. You have to spin that nut, while the drums are on, in order to adjust everything.
HUGE pain in the ***...
There is a tool for it, but a long std screwdriver will work just fine (its what Ive always used)
If you cant find the star though the hole, pull the drum, find it, make a mental note, and then replace the drum...
Old 06-16-2008, 05:33 PM
tortis's Avatar
Default Re: (pdiggitydogg)
you know, this is probably the one thing the engineers could have designed better. i love this car it is a snap to work , except the brake adjustment.
thanks for the help.
Old 06-16-2008, 06:13 PM
Oh...its ALL drum brakes...
Old 06-18-2008, 03:31 PM
tortis's Avatar
that job sucked real bad, but it is done, and now i have a damn good feeling brake pedal.
The_RedBaron
05-26-2014 01:10 PM
Blackhalo6
04-12-2013 10:16 AM
charlieboy88
01-04-2013 07:58 AM
sobey
12-20-2009 12:11 PM
garykf16
Suspension & Brakes
12-21-2008 10:39 PM
Quick Reply: Adjusting the rear brakes- drum
