adjust clutch pedal
Old 11-12-2009, 06:35 AM
heeltoehonda's Avatar
Default adjust clutch pedal
can anyone explain to me in detail how to adjust the grabbing point for my clutch pedal on a 94 honda civic with a 01 ls swap(hydro tranny) with a 6 puck clutch(if that makes a difference)
Old 11-12-2009, 07:05 AM
pauldizzle89's Avatar
Default Re: adjust clutch pedal
if it's anything like my 94' there should be a rod/bolt connected to the back of the clutch that runs through the firewall, on it should be a nut which is the locking nut, just loosen that then you should be able to turn the bolt, one way will make it catch faster and the other way will make it catch at the starting height for the clutch, the easiest way for me to work on it was have my window down lay on my back with my feet propped on the window seal and my head practically on the gas pedal
Old 11-12-2009, 07:52 AM
joelmatt89's Avatar
x2 this is exactly what i was gonna say, same thing goes for the break pedal as well.
Old 11-12-2009, 08:00 AM
Matt93eg's Avatar
X3. Just remember to adjust the switches(Cruise Control switch if you have it, clutch interlock safety switch) accordingly after you make the pedal adjustment
Old 11-12-2009, 08:05 AM
vtectouge's Avatar
how to deal with sloppy fuel pedal? how to tighten it up? done my brake and clutch pedal today
Old 11-12-2009, 08:27 AM
thumper64's Avatar
Fuel is done on the intake manifold. You have to loosen the nuts on the metal shaft and pull the metal part slightly towards the driver's side and tighten the nuts. Leave a little slack or your idle will be high. I did mine while the car was running.
Old 11-12-2009, 08:34 AM
thanks guys!
what would adjusting the switches do for me?
Old 11-12-2009, 08:58 AM
ChRiS_p123's Avatar
thanks guys!
it will allow your car to start, without the cluch switch adjusted the car doesnt read that the clutch is being pressed and will not start,as far as the cruise switch i believe it reads when the brake is pressed allowing cruise to be turned off when the brake is pressed. someone correct me if i am wrong
Old 11-12-2009, 09:16 AM
where are both switches located on the car?
and if i don't adjust the brake i wont need to touch the cruise conrol switch. correct?
Old 11-12-2009, 09:24 AM
ChRiS_p123's Avatar
they should be under the dash near the top of the pedals.
Old 11-12-2009, 09:31 AM
ok thanks
Old 11-12-2009, 09:37 AM
Matt93eg's Avatar
Correct, however there is also a switch on the clutch pedal to disengage Cruise Control as well. So when driving with Cruise Control engaged you can either
A. Push the Brake Pedal to disengage cruise control or,
B. Push the clutch in to disengage cruise control.
The 2 clutch switches will be close to the foot pad of the clutch pedal screwed into a bracket with a locknut.
correct?
Yes and no, You won't need to adjust the cruise switch for the brake pedal since you didn't bother the pedal, you will have to most likely adjust the cruise switch for the clutch though.
In the following drawing you will see the Clutch Interlock Switch, Clutch Cruise Switch, Brake cruise switch marked as 17, 18, & 19.
Old 11-12-2009, 09:42 AM
thanks a bunch guys!
your advice is greatly appriciated
Old 11-12-2009, 09:45 AM
Matt93eg's Avatar
Glad to help
dustinbs144
02-08-2012 11:53 AM
heeltoehonda
11-12-2009 08:37 AM
RDAYA0
01-08-2008 06:02 PM
crazy eyez killa
04-02-2004 11:27 AM
Quick Reply: adjust clutch pedal
