ACG fuse keeps blowing out (searched)
Do not purchase anything from me. -HT Staff
okay... i started my car for about 5 mins to let it warm up.. and all of a sudden it dies.. tried to restart.. turn the key over to on position.. and a solid CEL, and no fuel pump sound.. i look at my ecu and the hondata didnt have any power.. first thought was main relay.. swaped wit a friend.. same problem.. checked the fuses.. ACG fuse was out.. so i was like yes i found the problem replace fuse blows out again.. so now im like wtf.. im thinking theres a short somewhere.. anyone know where to check?
what car?
on an EG the AGC fuse powers....
SRS control unit (airbag)
EGR control (VX only)
VSS
Alternator
ELD
Cruise Control unit
PGMFI main relay
Gauge Assembly
Cruise Control main switch
have you been messing in any of those areas?
VSS
Alternator
ELD
Cruise Control unit
PGMFI main relay
Gauge Assembly
Re: (Relic1)
car is an eg wit h22...
the only thing i touched was the ground on the thermo housing, and fuel pump... i went back and forth and decided to putt the whole harness out and re-do it... but it started fine.. than it died 5 mins.. later?
Re: (THC_H22 PROJECT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THC_H22 PROJECT »</TD></TR><TR><TD CLASS="quote">car is an eg wit h22...
the only thing i touched was the ground on the thermo housing, and fuel pump... i went back and forth and decided to putt the whole harness out and re-do it... but it started fine.. than it died 5 mins.. later?</TD></TR></TABLE>
what size wire did you use?
have you gone through your new harness to make sure nothing is wrong?
Re: (Relic1)
i havent cut up all the tape yet.. but the wire frm the thermo houseing was in the harness.. i think its sensor ground r something it has 2 black, a black/red wire, bround/black wire.
Re: ACG fuse keeps blowing out (searched)
hello I seen threads all over with no answers when I had this issue bout month ago 3/18/13!! Okay so my acg fuse would blow as soon as I turn on , no start! I changed many things ecu, ignition cap rotor module, coil pak spark plug battery checked altenator, radio under hood/dash fuses... It is a short!!! That can make anyone loose there mind I even changed the fuel pump!!!! >>>> here's the RESULT N SOULTION N WAT WASSSSSS MY PROBLEM, my brother who was busy at the time finally looked at it, n he changed the fuel pump again NOT JUST THE PUMP LIKE I DID, the whole entire thing : turns out.... The was a short in the actual fuel pump ( no good) he changed it, looked me in the eyes as if ( I'm the snit) n bammm 3 weeks later my car as been running n no more acg fuse dying it took me ( a car clueless girl) 2 months to figure it out tears, frustration mental anger lol honda baby! N these acg fuses threads are all shitty n made me spend money here the pump cost me $40 after all I spent n did : hope it helps many ppl just change the entire fuel pump not just the pump pill!!! GOOOD luck my car 93 eg coupe 1.6
instrument
11-03-2007 02:26 PM
