Ac Problem: Charge system and Freon shoots out AC pressure release valve.
Old 06-16-2010, 10:30 AM
mac_24_seven's Avatar
Default Ac Problem: Charge system and Freon shoots out AC pressure release valve.
94 Del Sol Si.. AKa: Jellybean
Just like the title says.. You can create a vaccum on the system (with the pump) then charge it with Freon. When you turn on the AC it will start to blow cold and then the Freon shoots out of the pressure release valve on the AC compressor.
What could be the problem aside from a blockage somewhere?
Any ideas?
Old 06-16-2010, 10:48 AM
Former User's Avatar
Default Re: Ac Problem: Charge system and Freon shoots out AC pressure release valve.
Does the condenser fan run?
Is the condenser clogged with bugs?
Also could be a clogged condenser or condenser line.
Old 06-16-2010, 11:04 AM
Yes it does.
No, it's actually very clean.
I assume it is a clogged line somewhere but I'm no AC tech so it could be something else that I may not know about and somebody who knows more about AC system than me might
Chavy340
09-11-2014 10:33 AM
KGNickl
05-01-2008 01:59 PM
JasmitH
06-24-2007 07:27 AM
playahwitgame
08-10-2006 01:54 PM
Quick Reply: Ac Problem: Charge system and Freon shoots out AC pressure release valve.
