AC not working, Hot Stickiness!
AC not working. Here's what's going on & what I've done. (keep in mind idk much about AC systems)
97 civic ex
*AC light appears when button pressed.
*no AC fan or compressor engagement when pressed.
*Jumped Compressor relay & clutch engaged but not fan.(not sure if that's normal)
*Jumped pressure switch, fan kicked on but not comp. clutch(don't know if that's normal)
*Hooked up ac pro recharge kit and shows 20psi with AC off and 0psi with jumped clutch.
I read that when you press the AC button the condenser fan is suppose to kick on... Which mine doesn't..
Idk what else to do? Or what's the next step..
*I didn't add freon* since I read the fan is suppose to come on when AC button is pressed.
97 civic ex
Fish Twig
Re: AC not working, Hot Stickiness!
You have a leak that is causing your system to not run, you pressure switch is either clogged and is not detecting refrigderant, you're low on refridgerant.
Consult FSM to see where you should be on refriderant.
20 psi with A/C off indicates the A/C system is basically empty of refrigerant.
Jumping the A/C pressure switch should not trigger the fan to run. Did you instead ground a wire in the switch connector?
Did you test fuses 56 and 17?
i added UV freon jumping the comp clutch and now with the AC off the psi is in the red with the AC on the psi is 25. but now my AC light on the heater controls wont come on. i will check fuses and report back.
and you are correct, i did not check the actual switch i bridged the connector pins together and the AC fans activated.
Fuse number 17 is good so is 56.
H0w do i check the relays for the fan and compressor A B C ???
Post a picture of the pressure switch connector you jumped.
Jumping the connector should NOT activate a fan.
Fuse testing:
https://honda-tech.com/honda-civic-d...fuses-3079359/
my apology i only meant the condenser fan. i will try to be more thorough in my descriptions.
i will get a picture up asap. it is behind the drivers headlight somewhat underneath the power steering fluid tank.
well i jumped the connector again and nothing happened.. i wonder what it was that made the fan turn that i confused with the pressure switch =/
the connector between the power steering tank and washer fluid tank is the pressure switch correct?
I will test those fuses right now.
on a side note. i turned the car on activated AC button (it lit up) grounded each of the terminals on the CONNECTOR(not the switch itself) separately and one turned on the fan. Grounding the other terminal engaged the clutch. idk what that means just throwing it out there..
Next test:
Plug pressure switch back in.
Unplug A/C thermostat.
With key in ON(II), ground the Blu/Wht wire pin in the thermostat connector.
Does fan run and clutch engage?
SWEET!! i looked and that connector was unplugged! grounded the blue/white wire and fan/clutch engaged! connected it back into the AC thermostat, started car, and BAM! AC comp and fan are spinning! =]
David Guevara
19
04-09-2016 06:44 AM
94_civicEx
Honda Civic (2006 - 2015)
06-13-2014 12:28 AM
