ABS??
Old 07-28-2007, 07:44 AM
Cschwind777's Avatar
Default ABS??
I got a 93 dx was wonderin if it had abs/how do i find out
also i ordered the rear disc brake setup from H motors they said they gots everthing for the swap cept for praportioning valve which i can get off of a civic ex 92-95 but i thought ex had abs....not sure if this will work if i don't have abs...?
Old 07-28-2007, 08:02 AM
pdiggitydogg's Avatar
you dont have abs
FEW ex had abs
you dont have to worry about anything, as far as abs parts or not...just dont worry about it
it will work
Old 07-28-2007, 09:28 AM
H-T White Ops
NOFX's Avatar
To clarify, all EX sedans had ABS, but only some EX coupes had ABS.
The '93 DX coupe, hatch and sedan did not come with ABS though.
Old 07-28-2007, 10:44 AM
Default Thanks but
thanks yo
but are all civic brake pad and rotors the same for 92-00 civics??
does abs make a difference in pad an rotor selection??
Old 07-28-2007, 11:00 AM
no there are different front pads
abs uses 10" rotors, same as ex/si
all rear rotors and pads are the same
04-20-2006 04:00 PM
nurvcom..
12-19-2005 09:31 PM
94eg!
16
05-12-2005 08:43 AM
pburke23
06-05-2004 11:00 AM
GetawayInMoscow
10
03-28-2003 01:49 PM
Quick Reply: ABS??
