[FAQ] ECU thread. Codes, wiring pinouts and more. New and Improved Ecu thread :)
DELETED!!!!
Modified by JDMlyfestyle at 3:58 PM 2/18/2007
Re: [FAQ] ECU thread. Codes, wiring pinouts and more. New and Improved Ecu thread :) (JDMlyfestyle)
once again good ish man i think this should DEFIANTLY BE STICKIED
edit: damn i should have quoted everything too
Re: (JDMlyfestyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle »</TD></TR><TR><TD CLASS="quote">lol if you qouted everything i would have gave u a internet *** woopin</TD></TR></TABLE>
i just might have too now
Re: (Advan06)
you have to run uberdata for that method of datalogging to work i believe, you chip your ecu with a basemap from uberdata with the datalogging capability. Then connect the cable and go to this tab: and you can datalog, just click the boxes of the sensors you want included, then select the com port
and here is a pic of my desktop cause i was really bored tonight
Modified by Soccerking3000 at 10:03 PM 3/7/2005
My sister car got stolen and so we decided to buy it back from insurance..The wiring in the car is all cut up and it need repair.....
Question is : the ECU wiring plug in is gone and Can I splice and solder the wires together,will that be ok for the ECU?
Modified by OVA at 8:20 PM 3/11/2005
Re: [FAQ] ECU thread. Codes, wiring pinouts and more. New and Improved Ecu thread :) (OVA)
you shouldnt the resistance in the wires could change and thus change the sensor readings that the ecu interprets yourbetter off with a new uncut harness
Is it the same way with the Del Sols? my check engine lights on and i was wondering if it was the same.
Re: [FAQ] ECU thread. Codes, wiring pinouts and more. New and Improved Ecu thread :) (Soccerking3000
Hi
Question: I'm swapping the B16A2 in my Del Sol .
I pick up new water pump PT. 19200-P72-013 it's for the B18c1 or B18c5, Plus the B16A2,3 or Vtec timing belt..Did I get the right combination together for my engine?
Question I have a 2000 civic si, I have had a check engine light forever it's blowing a 67 I swear I have checked and reset and checked and reset a million times same code every time. Any clue as to what this is?
Any help would be greatly appreciated.
Re: (OVA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OVA »</TD></TR><TR><TD CLASS="quote">ttt</TD></TR></TABLE>
dumbass newbs this is a sticky it never leaves the top
Re: (JDMlyfestyle)
dumbass newbs this is a sticky it never leaves the top</TD></TR></TABLE>
hahahahahahahaHAHAHAHAHA
