99 Si P1259 False Error?
Old 07-14-2014, 03:54 PM
DennisEM1's Avatar
Icon2 99 Si P1259 False Error?
Yesterday while I was on the freeway merge, I decided to hit VTEC in first gear and I sort of accidentally went to 8400 ish with my JDM B16A. For some strange reason, I got the P1259 right after. This is only my second time I have exceeded the 8200 redline, and the rev limiter didn't come on or anything.
The strange thing is, the car felt fine, the VTEC system seemed to be working and all that on the freeway merge yesterday. Anyways, after the check engine light, I noticed that VTEC was still engaging at 5200 RPM, but would get rev limited at 6800.
Today I took off the VTEC solenoid and checked it out along with the gaskets. The connectors are clean, and there is no gunk in the solenoid gasket mesh, so I proceeded to put it back together and cleared the check engine light. After that, I went to take the car for a spin on the freeway merge again, VTEC kicks in strong as usual at 5200, and I drove it to about 8200 RPM for 4 gears. Everything seems fine, the power is there, and there is no sluggish feel. Could this be a false error code? I know that if it isn't a false error code, it should come back again. I have Googled this error code btw and have that diagnostic instructions from HELM on my phone ready to use in case it comes back, but would like to see if anyone has any ideas.
Thanks in advance.
Old 07-14-2014, 04:06 PM
The Grumpiest
grumblemarc's Avatar
Default Re: 99 Si P1259 False Error?
How do you figure it was false? Maybe stop beating on the car.
Old 07-14-2014, 04:07 PM
The Grumpiest
Here's an experiment; Try doing EXACTLY what you did to throw the code the first time. See if it happens again.
Old 07-14-2014, 04:14 PM
DennisEM1's Avatar
Well, I usually redline the car a good one time every two weeks or so to beat on it truthfully. But I shift at 8000-8200. This time however, I was a little later than usual, and shifted around 8400, and the check engine light surprisingly came on. Today it was fine though at 8200 when I was trying to see if it would come back on again. It's 200 RPM less, but yeah.
EDIT:
Also changed my VTEC solenoid gasket about a year ago, and it's still in good shape.
Oil was changed about 3-4 months ago, so that's not an issue either.
playin4keeps
11-24-2010 04:16 AM
jevan ayala
09-10-2009 04:41 PM
lukeroath
01-25-2009 01:37 PM
lukeroath
01-25-2009 09:18 AM
crxracer2006
10-20-2005 07:22 AM
Quick Reply: 99 Si P1259 False Error?
