Old 03-25-2015, 11:04 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
Print Wikipost
99 Si check engine light question - where is plug for scanner tool?
Old 07-18-2011, 01:43 PM
integratyper1990's Avatar
Default 99 Si check engine light question - where is plug for scanner tool?
How do you get the check engine light codes that start with the P101 example
I have a 99 honda Civic EX with a 99 SI ECU GS-R Swapped Where is the plug for the scanner tool to go into (obd2 plug)
I know how to check it with the two pin plug= if i do it this way are the codes still the same
Old 07-18-2011, 01:47 PM
Former User's Avatar
Default Re: check engine light questiond
For some CEL codes, you get more information from the OBD2 code than from the OBD1 code. It's near the hood release lever:
Old 07-18-2011, 01:48 PM
Thanks man.
MBlake55
27
03-01-2013 06:50 AM
apoptosis
01-19-2008 04:42 PM
juniestyle
12-04-2006 08:40 PM
DeDonDeRosa
04-03-2006 04:11 PM
beat_nut
01-11-2005 01:19 PM
Quick Reply: 99 Si check engine light question - where is plug for scanner tool?
