99 civic wont start - Honda-Tech
99 civic wont start
Old 05-09-2013, 03:47 AM   #1
Icon3 99 civic wont start
I have a d16y7 and cant get it to fire. Ive changed plugs, wires, cap, rotor, fuel pump, filter, tps, map sensor, iac valve, checked vacuum system for leaks, cleaned system with seafoam(both vacuum and fuel). Still cant find a remedy. This began with a low idle at startup. Turned into low idle and loss of power. Then became a jerking on acceleration and not wanting to stay running at startup. Now it just will not start. Any ideas? Please help
MrMiller is offline   Reply With Quote
Old 05-09-2013, 03:53 AM   #2
silkypillows's Avatar
Default Re: 99 civic wont start
cel on? does the cel function?
silkypillows is offline   Reply With Quote
Old 05-09-2013, 05:12 AM   #3
Yes, its thrown a map sensor and tps code along with a vtec malfunction and an automatic transaxle code (0740)
Old 05-09-2013, 08:13 AM   #4
Engine swap? Your ECU doesn't match the engine, and also possibly the transmission.
If you reset the ECU do any of the codes return?
Do the no-start basics - pump prime and spark?
Former User is offline   Reply With Quote
Old 05-09-2013, 07:24 PM   #5
It was the coil. Still have the original hesitation, rough idle, loss of power and stuttering on acceleration. Any thoughts?
Old 05-09-2013, 09:50 PM   #6
ej7attack's Avatar
injectors could be clogged some not allowing you to get sufficient fuel. or a major vacuum leak your not noticing. check everything,components,hoses for leaks. and also check the FIA valve for functionality. Fuel Injection Air control valve.
ej7attack is offline   Reply With Quote
manufacturer controlled ignition system or misfire dtc ek gsr swap efgkkid Honda Civic / Del Sol (1992 - 2000) 4 09-26-2012 05:43 PM
bouncing idle ? SpoolnEG6 Honda Civic / Del Sol (1992 - 2000) 3 12-06-2008 12:10 PM
Rebuilt Motor - Not Your Average Idle Problem....? lsturbo* Acura Integra 3 10-15-2008 10:17 AM
H22A4: Weird startup idling and shutdown problem, need input CXHATCHver2.2 Honda Prelude 3 04-08-2005 11:43 PM
help with low idle during startups 00b18b Acura Integra 4 06-15-2004 06:55 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
