roller rockers on a d16z6?
Old 05-07-2013, 06:49 PM
cyandan's Avatar
Default roller rockers on a d16z6?
Hey, guys I just saw a post that said one of the members here was selling a D16z6 head with roller rockets from a D15b. but what I would love to know is what year D15b would you actually be able to use the roller rockers that will fit on the D16z6 head.
Old 05-07-2013, 06:53 PM
B_Swapped93's Avatar
Default Re: roller rockers on a d16z6?
do you mean the rocker arms...
Old 05-07-2013, 07:05 PM
emergencybm's Avatar
I think he means from a VTEC-E head I believe they had roller rockers
Old 05-07-2013, 08:10 PM
EGxBoostFiend's Avatar
Is this for real? Like can you do that? If i did this could i expect to see higher hp numbers? This is the first time i've heard of this.
Old 05-08-2013, 05:27 AM
apexi_rsx's Avatar
only the vtec E motors had roller rockers... and i believe they are not innerchangable between d series heads
Old 05-08-2013, 06:19 AM
been there done that
doood's Avatar
what exactly do you hope to achieve with roller rockers?
Old 05-08-2013, 06:25 AM
The Grumpiest
grumblemarc's Avatar
In for the answer. I'm sitting here scratching my head.
Old 05-08-2013, 07:57 AM
I read about this last night, correct me if im wrong here guys. I read that you can use the D15z1 Vtec-E roller rockers. But in order to use them you have to use the z1 camshaft too. So it being more Economical oriented engine i dont think anybody really see's any advantage to using them.
Old 05-08-2013, 08:03 AM
Technical Hero
HondaPartsHero's Avatar
I believe entire valve train swaps (including cam) are possible between the Y8 and Y5 and also Z1 and Z6. I've read multiple posts on people that have done it. But the cam must match the valve train.
Old 05-08-2013, 08:04 AM
The Grumpiest
So what's the benefit?
Old 05-08-2013, 08:08 AM
apexi_rsx's Avatar
from an old honda tech post
"This is, by far, the worst idea I've ever had (the whole reason I'm deleting it). The rocker arms didn't line up properly, the cam caps needed to be align honed, and it would need an oversized custom cam made." No one makes cams for the vtec e head...
Old 05-08-2013, 08:15 AM
The Grumpiest
Second question; what was it about "roller rockers" that people thought would net them so much horsepower?
Old 05-08-2013, 09:06 AM
98ekb18c's Avatar
I'm guessing the theory is less friction in the valvetrain=more power. That's what I've always assumed being raised in a domestic v8 family. In a built race motor I can possibly see a benefit. In a d series I wouldn't waste the effort.
Old 05-09-2013, 05:30 PM
cyandan's Avatar
Guys roller rockets are not so much for horse power gains as much as for quick revs.
This would work best if you had a lite flywheel and lite weight pulleys. Roller rockets have much
Much less friction than the stock one. And so therefore will rev faster.And if it really didn't do anything why would Honda invest millions and millions to have them on all the si 2009 models and up. I hope I can find some answers and not a lot of negative talk.
Old 05-09-2013, 05:34 PM
you were given the answer a few posts up here>>
Old 05-09-2013, 05:35 PM
cyandan's Avatar
Some member on this site claims he installed some roller rockets on his D16z6 head and I would like to hear from someone who has either done this or know what motor these came off of and no its not the hx with the vtec-e this one will not work because it does not have the third vtec lobe.
Old 05-09-2013, 05:36 PM
Ya there's a lot of that on here....
look at my last post
Old 05-09-2013, 05:37 PM
The Grumpiest
But we're not talking about 2009 models and up are we? We're talking about tired old D-series engines. And do you honestly think that after all these years this idea wouldn't have caught on like wildfire if it actually worked?
So ask him how he did it. maybe he's all talk.
Old 05-09-2013, 05:50 PM
cyandan's Avatar
Hey, let me just say just one things ,most if not all real race motors have roller rockers that's why Honda decided to put them on the new si. End of story. They do something now if you can't use your imagination an see with your mind a wheel rolls and a pallet slides. Stop the negativity. I don't see the point to a lot of things people do to hondas but I respect that if they want to spend the money to do it more power to them.
Old 05-09-2013, 05:52 PM
The Grumpiest
Then be the pioneer and do it. It was already demonstrated by someone in the past that it was attempted and it was a fail. If you think you can be successful then do it and stop talking to us. Dreamers talk. Trailblazers do.
Old 05-09-2013, 05:53 PM
If this was doable don't you think there'd be many more threads on it....ya you're in no place to tell us "end of story" by the questions/responces you're posting
Old 05-09-2013, 11:01 PM
Technical Hero
I guess it would easier than a head swap say from an HX to an EX for "performance" or from an EX to an HX for MPG. To my knowledge you can't just swap the roller rocker portion from an HX and use an EX cam, nothing would line up. Same applies to VX (D15Z1) to an EX/Si (D16Z6).
Old 05-09-2013, 11:45 PM
jbpnoman's Avatar
When you can actually understand all of the benefits of roller rockers, then you can say "end of story". The fact that you think Honda spent "millions and millions" to switch to roller rockers in the '09 SI is comical, too. On top of that, you seem to think that Honda switched to roller rockers because "race motors have [them]".
Are Z1 roller rockers a direct bolt-in for a Z6 head? No. OP, if you're actually interested in doing this, look into using a Y8 head rather than a Z6 head. Some time researching this idea will tell you why.
p3p69
08-25-2013 08:56 AM
EvilT
09-29-2006 10:44 AM
CivicHB91
01-23-2003 03:30 PM
Quick Reply: roller rockers on a d16z6?
