99 Civic si - Speedo crazy
Old 10-18-2015, 03:13 PM
Hawaiianhonda's Avatar
Default 99 Civic si - Speedo crazy
Hey everyone, so I've come across the irratic speedo problem on my 99 si with 127k. Wen I turn the key on,it will either jus bump up n down real fast or bump up to 20 mph and stay their, so I unplugged the vss and same problem still exists,I haven't had time to go more in depth but I do notice my idle is higher wen the vss is plugged in but that happens wen the speedo goes in and out of working.
Old 10-18-2015, 03:33 PM
Former User's Avatar
Default re: 99 Civic si - Speedo crazy
Post the CEL codes.
Is fuse 15 blown?
Old 10-19-2015, 01:49 AM
Thanks for the reply bro, no fuses blown from wat I see it I'll check wen I get up, wats fuse 15? And theirs no cel either :'(
Old 10-19-2015, 11:45 AM
I never narc'd on nobody!
NotARaCist's Avatar
Does the CEL work? It should come on for 2-3 seconds when you first turn the key to ON(II).
Old 10-24-2015, 03:44 PM
Default Em1 - will the vss from any other Civics work?
Hey everyone, I'm searching to buy a vss for my 99 em1 and was wondering wat or if any other model civics(sohc,sohc,dnt matter) vss would bolt/work iny b16?
Old 10-25-2015, 01:27 PM
Default Re: Em1 - will the vss from any other Civics work?
Bumpy
Old 10-25-2015, 11:31 PM
Yes, cel cycles as should. I pulled the ecu and looked under the cover, everything looks good per say.
Old 10-26-2015, 03:04 AM
crazyhorse2011's Avatar
*per se
Old 10-26-2015, 03:06 AM
Stancetard Hate Monger
eghatch9295's Avatar
bad speedo or cluster. common symptoms.
Old 10-26-2015, 10:04 AM
Jimster480's Avatar
Usually when that happens to me its because there is water in the speedo plug.
My car used to have a coolant leak that would sometimes spray there.
Check your speedo and see if you find any water in the plug.
I blew mine out with a can of air and left it off during a dry day and it didn't happen again.
Old 10-31-2015, 08:55 AM
Seagull Management
94EG8's Avatar
No, but one from a '94 - '01 Integra will work.
Old 11-01-2015, 08:35 AM
REDEM1FTW's Avatar
Yes! 100% yes. You can use one from a sohc motor (must be from a manual and must be a hydro tranny). All you have to do is remove the small cotter pin from each VSS, and then install your EM1 gear from end of vss onto the SOHC one! Reinstall cotter pin, install into your vehicle, and hit the road!
I have done this 156734 bajillion times, so trust me... it works!
Good luck to ya, hope you enjoy your new working vss!
- Josh
Old 11-02-2015, 02:35 AM
I live in az so its hard to say their is a water leak, I've pulled the cluster several times and connectors were bone dry. Anyone have a parts cluster they wanna sell
Old 11-02-2015, 07:59 AM
Josh, mahalos (thank you) for the info, I felt like it would work cuz they look similar but I'll do that :-) thanks again brotha :-)
Old 11-02-2015, 09:44 AM
djedd's Avatar
This is gonna sound weird, but that happens to my 94 Honda when my battery is old and not giving enough volts/amps when starting the car.
How old is your battery?
If you want you can just go to a shop and get the battery tested.
Just wanted to give my 1 cents of input as this exact problem happened to me a few times.Use it, don't use it.It's your choice.
Old 11-02-2015, 10:35 AM
REDEM1FTW's Avatar
Np man! Swap the gear then dissapear happen to have any pics of your em1? I just picked up a bone stock 2000 EBP EM1 last week!
Old 11-02-2015, 11:04 AM
Fish Twig
tony_2018's Avatar
I figured this was what needed to be done just wasn't sure. Good to know.
Old 11-03-2015, 11:23 AM
95streetciv's Avatar
Tap on the speedo window, while moving.
Mine acts stupid, or gets stuck at a certain speed.
I tap on the window and it goes to where it should be.
Thinking its a bad connection in the dash somewhere.
Old 11-03-2015, 12:15 PM
thatseemslegit's Avatar
Check all grounds. I had the same issue when i had a loose ground to the body. However all of my gauges were affected when my ground was loose.
Old 11-03-2015, 12:26 PM
Jimster480's Avatar
Its not the cluster connectors, its the connector to the VSS. There is a coolant line above it (throttle body) that can easily drip on it.
I've seen it many times.
Old 11-09-2015, 07:01 AM
Old 11-09-2015, 07:06 AM
I have no coolant leaks and I've inspected the harness above the sensor and seems fine. Battery is a couple years old but I did take the cluster aprt ish, popped the needle off, hooked it up and turned the key on and I could see the stem of the needle move so I figured put the needle where it should it would stay at the bottom but no matter wat I did, it went back to the same spot so I feel the speedo cluster itself is no good
Old 11-09-2015, 07:14 AM
Jimster480's Avatar
It could be that the cluster itself went bad, I've seen it happen before. Just not in any vehicle I have owned.
sikefcrx89
Engine Management and Tuning
04-27-2017 08:16 AM
sikefcrx89
04-27-2017 08:15 AM
BNSTKSI
07-18-2011 09:49 AM
zildjianmatt
02-11-2010 07:09 AM
Choy
21
07-27-2009 06:48 PM
Quick Reply: 99 Civic si - Speedo crazy
