99 civic no spark after coil. - Honda-Tech
Old 02-15-2017, 08:57 AM   #1
Default 99 civic no spark after coil.
I read a forum on the no spark issue and performed the tests within the link. It stated that if you have spark at the coil and the rotor turns then replace the cap and rotor. I did that and I still have the same problem no spark out of the cap to the wires. Any suggestions for a cure?
Erik Nielsen is offline   Reply With Quote
Old 02-15-2017, 06:50 PM   #2
Default Re: 99 civic no spark after coil.
How you testing for park at the coil. It might be that the spark is not strong enough.
prodjay10 is offline   Reply With Quote
Old 02-16-2017, 04:39 PM   #3
tamboo's Avatar
did you use a high energy ignition spark tester? (dirt cheap on ebay)
if not you may have damaged the coil.
Advanced Ignition Troubleshooting - Team Integra Forums - Team Integra
tamboo is offline   Reply With Quote
99 civic no spark after coil. Erik Nielsen Honda Civic / Del Sol (1992 - 2000) 3 02-15-2017 05:07 PM
Intermittent Spark Issue help? RedEJTwo Honda Civic / Del Sol (1992 - 2000) 7 05-09-2015 01:11 PM
1992 accord no spark no start kenwolf Honda Accord (1990 - 2002) 6 11-21-2010 02:06 PM
No Spark EGLUVN Honda Civic / Del Sol (1992 - 2000) 5 05-17-2007 12:53 PM
HELP NO SPARK EJtypeR All Motor / Naturally Aspirated 9 04-23-2005 07:02 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
