99 civic ex pulsating lights - Honda-Tech
Old 12-31-2011, 12:45 AM   #1
///Nick's Avatar
Default 99 civic ex pulsating lights
so, ive had this problem since i got my car. apparently its a common problem. and it happens to me often, my lights pluse for very long periods of time, sometimes it doesnt but most often it does. its easy to tell at night time. all of my interior/dash lights pulse, tail lights and turn signal bulbs (not my headlights because i have hid's installed)
lots of people tell me its due to my sterio. i have a subwoofer and amp setup along with a big 3 upgrade. but i know for a fact this has nothing to due with it simply because ive had this problem before i installed the sterio.. when the car was bone stock.
ive looked online at some tsb reports and fix-it procedures and they say that its due to some "electronic load sensor" that is placed under the intake maniford. ive taken out this harness and inspeced it as best as i could and didnt notice anything unusual about it. the electronic connectors seem to be connected well. some other people say its a blown fuse but i have NO blown fuses at all.
so im a bit stumped and dont know where to go from here. any help would be great. its really annoying even though im pretty sure no one else notices it.
///Nick is offline   Reply With Quote
Old 12-31-2011, 01:13 AM   #2
hunan beef's Avatar
Default Re: 99 civic ex pulsating lights
Any Cels?
hunan beef is offline   Reply With Quote
Old 12-31-2011, 01:28 AM   #3
///Nick's Avatar
nope. none at all
Old 12-31-2011, 06:12 AM   #4
hunan beef's Avatar
Yikes.
Start with your grounds. There may be something that's dirty or corroded.
Old 12-31-2011, 06:20 AM   #5
could be ur alt going out ... but also could be #15 fuse check that
Mobeious is offline   Reply With Quote
Old 12-31-2011, 07:43 AM   #6
MikNomis's Avatar
EDIT: Never mind
MikNomis is offline   Reply With Quote
Old 12-31-2011, 07:56 AM   #7
I'd take off the alternator and get it bench tested, it will check the voltage regulator. Like Hunana said, check your grounds and for corrosion depending on climate a 12 year old car may have issues.
jollygr33n is offline   Reply With Quote
Old 12-31-2011, 11:03 AM   #8
///Nick's Avatar
alt is working fine. i have 0 gauge wire running from my alt to my battery with 200 amp fuse in between it. all my grounds are 0 gauge wire and ive checked fuses both under the dash and under the hood.
Old 12-31-2011, 11:05 AM   #9
Quote:
Post data (e.g., voltage measurements) to support this conclusion.
Former User is offline   Reply With Quote
Old 12-31-2011, 11:05 AM   #10
The Grumpiest
grumblemarc's Avatar
None of this means your alternator is "running fine". Have it tested or test it yourself using a multimeter.
grumblemarc is offline   Reply With Quote
Old 12-31-2011, 11:40 AM   #11
///Nick's Avatar
used a mmeter im at 12.7 volts with the car off. when i start the car im at 14.5 volts. all my connections and grounds are clean.
Old 12-31-2011, 12:41 PM   #12
this means nothing .. what is the alt doing under load
Old 12-31-2011, 01:48 PM   #13
///Nick's Avatar
well i had my brother turn on the ac and turn on the radio. the voltage dropped to 13.5 and then very quickly went back up to 14.7
Old 12-31-2011, 02:04 PM   #14
Turn all the electrical accessories on with the warm engine idling and watch for whether the voltage across the two battery posts fluctuates over a few minutes of observation. You'll get the most information if you make voltage readings when the lights pulsate.
Old 01-09-2012, 10:43 AM   #15
///Nick's Avatar
found the problem, my charge wire (connects to alt and battery) was rubbing on some other wires, no bare wire contact. all the rubber around the wires are fine. just a wierd electrical issue. to fix this i losened the 10mm bolt on the alternator and turned the wire closer to the engine block.
Old 01-09-2012, 10:46 AM   #16
The Grumpiest
SOLVED!!
Old 01-09-2012, 10:47 AM   #17
///Nick's Avatar
who would have known it was somthing this simple
Old 01-09-2012, 10:48 AM   #18
The Grumpiest
It usually is. And it makes me mad.
Old 03-02-2012, 10:42 AM   #19
///Nick's Avatar
well... car got in front end collision (not my fault) got it back from hinshaws honda body shop a few days ago. problem is now back. could it be this electronic load sensor under my intake manifold?
Old 03-02-2012, 10:46 AM   #20
The Grumpiest
Quote:
Did you ever perform this test?
Old 03-02-2012, 12:05 PM   #21
///Nick's Avatar
will do now. i got a new dmm
Old 03-02-2012, 12:33 PM   #22
///Nick's Avatar
so, car off it was reading 12.87v
turned the car on (cold) it would sit at 14.57 then in a second it would jump around to 14.6 to 14.8 to 14.9 then back down to 14.57 (not so stable)
then once car was warmed up it sat at 14.5 and after a while it would go to .6, .7, down to .4 then back to 14.5 and repeat after a while.
turned on my cd player (sub off) at a moderate level where you can still have a conversation, heater on fan half speed voltage was steady 14.46 to 14.47 volts
then i turned on my headlights (hid bi xenon) would jump around 14.35 to 14.47
so, quite alot of jumping around on the mm
Old 03-02-2012, 06:31 PM   #23
new alternator maybe? take it off get it tested at autozone?
just my .02
Jdmbryan is offline   Reply With Quote
Old 09-27-2012, 06:18 PM   #24
I know it's an old post but any conclusions? I have a 97 dx and am having the same issue. Any help would be appreciated
Jgreen94 is offline   Reply With Quote
Old 09-27-2012, 06:45 PM   #25
longest project ever
lostforawhile's Avatar
Location: on the south side of dixie, 1986 Accord Hatch
the only thing that would cause this on a number of different circuits is the alternator or it's wiring, it's possibly a regulator failing or possibly a bad diode, turn the meter to low voltage ac and see if you read any AC component, also why are you running such a huge wire from the alternator, is it a stock alternator? you shouldn't need more then 2 gauge, I wonder if the huge wire is putting a mechanical strain on the output terminal at the alternator, this is very possible. the fact that it did this when rubbing the other wire also says this, this caused more load on the alternator terminal, that terminal is not designed for 0 gauge wire
lostforawhile is offline   Reply With Quote
Brand new battery but stereo resets and no spark Eddygee53 Honda Civic / Del Sol (1992 - 2000) 33 10-18-2015 04:44 PM
Battery Light stays on SL0RD Honda Civic / Del Sol (1992 - 2000) 2 02-02-2012 09:18 AM
NO Brake lights SoB NiG Honda CRX / EF Civic (1988 - 1991) 11 10-28-2010 11:16 AM
No power starting up? sTill JDM Honda Prelude 1 05-19-2007 08:38 PM
replaced alternator, replaced battery, car still won't start (del sol) cozmo2312 Honda Civic / Del Sol (1992 - 2000) 8 08-10-2004 05:47 PM
Tags
2000, 99, car, civic, headlights, honda, interior, ligh, lights, night, pulsating, pulse, pulsing, starting, voltage
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
