'99 Civic EX P1399 - Possibilities? Help!
Old 01-19-2010, 05:27 PM
ctownintegra's Avatar
Icon3 '99 Civic EX P1399 - Possibilities? Help!
Wife called from 45 miles away from home, said it felt like she hit a brick wall, that there was an instant loss in power. I drive there, crank it and it sounds like it is running on 3 cylinders. I check the code and get a P1399 - Random Misfire, no other codes, just the P1399.
I thought maybe it was the cat, but it will rev all the way up and down, but rough. It will drive 70mph, just takes a while to get there.
Cap and rotor were fine, going to pull the plug in a moment,
Wires were also fairly new.
Ideas?
Old 01-19-2010, 05:50 PM
Default Re: '99 Civic EX P1399 - Possibilities? Help!
Changed the plugs, got 3 more codes now.
P0301 - Cyl 1 Misfire
P0303 - Cyl 3 Misfire
P0300 - Random / Multiple Cylinder Misfire
Going to possibly try a dizzy tomorrow.
Old 01-19-2010, 06:08 PM
skaternak's Avatar
any oil on plugs? gapped properly?
Old 01-19-2010, 06:10 PM
skaternak's Avatar
correct fuel octane? cause i was using 89 in my d16 and went to 87 cause low on money. that whole time i had 87 in my car bogs runs rough and misfires (sometimes). deff change cap and rotor to be sure
Old 01-19-2010, 08:47 PM
No oil on plugs. Using the same brand/octane gas I have had since day one. New cap, rotor, wires. Now it won't idle. fluctuates between 1k-1.5k with the check engine light flashing, and misfiring like a big dog.
Old 01-19-2010, 08:52 PM
skaternak's Avatar
I GOT IT!!! i hope, lol. check the coolant level, and bleed it.
Old 01-19-2010, 08:53 PM
optionRej6's Avatar
theres like a lil gasket of rubber inside the plugs for the fuel injectors take it out from the one that the cylinder doesnt have any spark thats what happened to me when i had an ls try it maybe it will work
Old 01-20-2010, 07:26 AM
PROBLEM FIXED!
Checked the resistance on the wires, 7kOhms on the shortest one.....bad
Pulled cap, then coil....coil had a crack in it and was arcing out of the casing.
New MPI coil, new BWD wires from o'reilly's and we are back on the road with all 4 cylinders!
bunnyx
02-16-2014 10:10 AM
Chriser0
20
01-16-2014 08:02 PM
CPTN
05-21-2011 09:25 PM
EJ8_Enthusiast
06-15-2009 06:02 PM
shortlid
01-10-2008 05:44 PM
Quick Reply: '99 Civic EX P1399 - Possibilities? Help!
