99 Civic EX - P0420 Code - Honda-Tech
Old 06-11-2009, 11:53 AM   #1
New User
Default 99 Civic EX - P0420 Code
Hi All,
I just replaced my upstream and downstream O2 sensors and now I'm getting a P0420 code. I had my catalytic converter replaced a little more than a year ago, so I'm hesitant to have it replaced again. The car does have some issues when cold. When accelerating from a dead stop, the car stumbles (has new plugs and wires) and doesn't accelerate like it should. I think the P0420 code may be somehow related to the stumbling issue. Anybody experienced something along these lines before? Any suggestions on what to look at first?
Thanks
older_honda is offline   Reply With Quote
Old 06-11-2009, 12:08 PM   #2
Default Re: 99 Civic EX - P0420 Code
A rich running engine can kill a cat pretty quickly. It's best to fix O2 sensor issues first and then replace the cat.
If the cat turns out to be fine, then look for an exhaust leak.
Former User is offline   Reply With Quote
Old 06-11-2009, 12:18 PM   #3
New User
I just replaced both O2 sensors about a week ago. Now I have the CEL and P0420 code. I'll check for exhaust leaks.
Old 06-11-2009, 12:40 PM   #4
99civicsiguy's Avatar
do u have an exhaust on your honda? because ever since i got my exhaust i can't get that damn code to go away and i know my cat and o2 sensors are good
99civicsiguy is offline   Reply With Quote
Old 06-11-2009, 12:44 PM   #5
New User
Nope, the exhaust is an OEM replacement. My car is overdue on the inspection, so I'm trying to get things in order so it'll pass.
Old 06-12-2009, 05:12 AM   #6
New User
So I pulled the backup (7.5A) fuse last night to reset the computer. After just about 10 miles the CEL is back on. Now it seems to hesitate and stumble a bit more. Could the new O2 sensors be bad? I'm going to grab the CEL code tonight when I get home.
Old 06-12-2009, 06:09 AM   #7
New User
Anybody? Could a bad coil result in enough unburned fuel to trigger a P0420?
Old 06-14-2009, 07:41 PM   #8
Hello everybody. I have the same problem (1998 LX) and I think it's most likely the cat as the ECU indicates. Through some research on the net I found this TSB which might aid you as you mention the coil. It involves crimping the connectors at the igniter terminals.
http://www.tegger.com/hondafaq/p0420/A05-027.pdf
If it was the sensors it the ECU would throw more codes. I have an aftermarket 2 piece (flanged) exhaust manifold / catalytic converter and I myself am wondering if this two piece is better than a one piece unit. I've also heard of a bad ECT (engine coolant temperature) sensor that could throw this code but again wouldn't this throw a different code?
bhondap is offline   Reply With Quote
P0340 - 2003 Honda Civic DX Pryde Honda Civic (2001 - 2005) 1 12-18-2015 05:55 AM
2002 Accord p0420 code but stalls at stop? 2002accord4cyl Honda Accord (1990 - 2002) 2 11-12-2015 12:16 PM
Help with Engine Codes kaivorth Honda Civic (2001 - 2005) 3 05-28-2014 04:26 AM
Help with Engine Codes kaivorth Honda Civic / Del Sol (1992 - 2000) 2 05-27-2014 03:15 PM
2000 honda civic lx code p0420 tferro86 Honda Civic / Del Sol (1992 - 2000) 6 05-20-2008 08:13 PM
Tags
0420, 1998, 2003, 99, accelerating, cat, cel, civic, code, converter, honda, hondatech, mdx, p0420, stumbling, tsb
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
