fuel pump wont prime - 98 ex gsr bottom/built itr head/Hondata
Old 08-12-2011, 08:16 PM
4dr2k1civic's Avatar
Default fuel pump wont prime - 98 ex gsr bottom/built itr head/Hondata
Ok here's the deal drove my car home. Turned it off went to go start it again got nothing from the pump. Came back home and it started right up. Then drove it to work the next day. Went to leave got nothing. So got a new pump fired right up, but died 10 mins later while driving. So far I have checked all the fuses, cleaned all the grounds from threomosate, all the way to the tail lights, replaced the main relay with a new one, and even took out my hondata and pluged in another ecu. Will start once if I take the pump out and put it in again. I get power to the relay but not at the pump. Has me and 5 of my other co workers puzzled.
Old 08-13-2011, 01:30 AM
virgineg6's Avatar
Default Re: fuel pump wont prime 98 ex
check your wiring from the relay all the way to the pump, if your getting power at the relay obviously its some past the relay. make sure all the pins are making good contact and are not recessed.
Old 08-13-2011, 08:11 AM
speedstick345's Avatar
no power= bad wire
check for open circuit, ground, possible short.
Trace the wires from the pump
Old 08-13-2011, 12:24 PM
Former User's Avatar
I assume this isn't a stock set up. Give some details.
Old 08-13-2011, 12:39 PM
The Grumpiest
grumblemarc's Avatar
Why are you running Hondata?
Old 08-15-2011, 05:58 AM
delsolintegra's Avatar
I had that problem over a year. Everytime I changed the fuel pump it would "fix" the problem temporarily. I changed the main relay the PGM-FI relay, the ignition switch the ground wires cleaning etc. Turned out it was the ECU- moisture got to it. Got a used replacemant and it's been 6 months and no problem.
Old 08-15-2011, 08:31 AM
virgineg6's Avatar
How was it the ecu if you were getting power to the relay?
Old 08-15-2011, 01:55 PM
I have hondata because I am running a gsr bottom and built itr head and soon going boost
Old 03-28-2012, 03:52 AM
It was an intermittent problem that I believe was moisture effect on the ECU circuit board. Rainy mornings the problem was the worst. This went on over a year getting progressively worse. I suggest that anybody with a similar problem borrow or buy another ECU to see if it fixes it. Cheaper than a tow.
tonyj
05-10-2014 04:08 PM
Hiboost 2.0
04-29-2013 12:09 PM
hondaluver12
01-30-2012 02:37 PM
Hazeburner
08-31-2010 09:41 AM
integrapunk67
02-03-2007 09:51 PM
Quick Reply: fuel pump wont prime - 98 ex gsr bottom/built itr head/Hondata
