99 civic dx cranks but wont start, need ideas? - Honda-Tech
Old 02-21-2013, 09:59 AM   #1
infinkc's Avatar
Default 99 civic dx cranks but wont start, need ideas?
car is completely stock
it will crank but wont start.
car drove fine in the morning, parked and then wouldnt startup.
-Changed the Coil
-Changed the PGMFI Relay
-Changed the fuel pump
-Changed Fuel Filter
Pulled spark plug 1 and cranked, it was sparking
Undid the fuel line, cranked, fuel came out
Need your suggestions on what else may cause this car not to start.
Only thing it has aftermarket is an alarm, but the car cranks, so its not the starter kill.
infinkc is offline   Reply With Quote
Old 02-21-2013, 11:34 AM   #2
Default Re: 99 civic dx cranks but wont start, need ideas?
If spark is bright white at all 4 spark plugs, then check the mechanical timing. The timing belt may have skipped some teeth.
Any CEL codes?
Former User is offline   Reply With Quote
Old 02-21-2013, 02:20 PM   #3
infinkc's Avatar
no codes, if there was spark wouldnt the engine just run like crap?
Old 02-21-2013, 02:31 PM   #4
Weak spark generally won't run the engine.
Old 02-21-2013, 02:32 PM   #5
ironiceghatch's Avatar
Icon6 Re: 99 civic dx cranks but wont start, need ideas?
Quote:
Any CEL codes?
I drove my integra to work and shut it off. When i went to leave it wouldnt start and it had fuel and spark. It jumped timing. So I'd agree with this guy and Check your timing
ironiceghatch is offline   Reply With Quote
94 civic lx wont start has fuel and spark plz help 94_civic_dx Honda Civic / Del Sol (1992 - 2000) 1 11-05-2013 06:05 AM
cranks,but wont start niceprelude Honda Civic / Del Sol (1992 - 2000) 5 05-12-2012 10:34 PM
Honda Civic with B20 swap cranks but won't start Jonathannx2 Honda Civic / Del Sol (1992 - 2000) 8 06-02-2011 10:48 PM
wont start -Gambit- Honda Civic / Del Sol (1992 - 2000) 1 11-13-2005 06:38 PM
EF is cranking, but it wont start' vmm Honda CRX / EF Civic (1988 - 1991) 2 09-09-2005 08:12 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
