99 civic coupe 1.6 non-VTEC hard to start after running while engine is hot
99 Civic DX 1.6 non-VTEC is not starting after I run a few miles. Basically I drive it from work to the grocery store about 5 miles away and cut it off. Go in the store and come out and it spins over and smells like gas like an injector is flooding. Usually I have figured out that if I turn the key on and wait til the fuel pump cuts on and off, it will start better. A few times including today, it will idle really low and almost cut off. One of my other theories is that the Idle Control Valve is sticking and actually not letting it get the air it needs before it "floods" it. What do you guys think?
Re: 99 civic coupe 1.6 non-VTEC hard to start after running while engine is hot
Can you hear the fuel pump prime, the clicking noise near the glove box.
Does it start fine the first start of the day?
I would test fuel pressure and fuel pressure regulator.
What CEL codes are thrown?
Besides the fuel pump not priming, is there also no spark at the plugs?
Yes, RontJ@HT, the CEL is on, but for Catalyst flow I think. because there is no converter on the car. It has been this way the whole time I have had the car. I know it has spark, because it always tries to crank. It acts like a car with the carb flooded to me.
Are you tech savvy? If so check the fuel pressure and fuel pressure regulator. The flooded condition can be the FPR.
Broke_not_built
08-22-2011 10:40 AM
pavilionlivin
07-07-2009 05:33 PM
