99-00 Civics w/ gsr swap
what ecu are u running since you cant use the obd2b gsr ecu cause of the immobilizer. i know the way out is obd1. but im just wondering what everyone else is doing that hasnt done the obd2 to obd1 swap yet.
oh im running a 99-00 si ecu.
Re: 99-00 Civics w/ gsr swap (BlVlW313)
You can have the immobilzer removed.
But the easiest thing to do would be run an OBD 1 ecu. I think you already know that though
Re: 99-00 Civics w/ gsr swap (GReddy SI)
kenji ob2b-obd2 harness w/p72 no prblems at all.
try to stick to the same kind of ecu like jdm engine w/jdm ecu
cause if you use a usdm ecu on a jdm engine you will need a vtec press. switch and a CFS
Problemo
07-09-2005 06:49 PM
