99-00 Civic Remote Entry module location?
Old 04-23-2008, 09:40 AM
jfang's Avatar
Default 99-00 Civic Remote Entry module location?
Hi I was wondering where the remote entry module is located. My Si did not come with the actual entry remote, and my guess is that it probably has the module installed from the factory, i just wanted to make sure i had it before I go buy a remote. Could anyone tell me exactly where I can find it to see if i have this option? (i have tried searching but looks like the old topic has been removed...)
Thanks guys
Old 04-23-2008, 09:58 AM
Poppins324's Avatar
it is on the factory radio.
Old 04-23-2008, 10:35 AM
jfang's Avatar
only the 96-98 have the remote entry module in the radio. i know that for sure, for the 99-00 civics it's separate somewhere underneath the dash i think... i just need to know the exact location
Old 04-23-2008, 10:56 AM
jdmeg6118's Avatar
Default Re: (jfang)
Yea my 00 SI has a diff radio so it's not there for sure..umm
Old 04-23-2008, 12:19 PM
H-T White Ops
NOFX's Avatar
Default Re: (jdmeg6118)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmeg6118 &raquo;</TD></TR><TR><TD CLASS="quote">Yea my 00 SI has a diff radio so it's not there for sure..umm</TD></TR></TABLE>
For '99-'00 the keyless entry was NOT on the radio. So your car still should have it.
Old 04-23-2008, 12:25 PM
D50boy's Avatar
Default Re: (NOFX)
96-98 it's in the radio, 99-00 it is behind the kick panel by the drivers foot. Small whiteish grey box with 2 metal things to bolt it down.
Modified by D50boy at 3:31 PM 4/23/2008
Old 04-23-2008, 01:10 PM
jfang's Avatar
hey thanks a lot guys, i'll take a look today and let you know what's up
Old 04-23-2008, 01:52 PM
jfang's Avatar
hey thanks everyone for helping me out, i just took the kick panel out, and there it is. Just ordered a OEM remote for it and it should be coming in next week. this should hold me over until i get a real alarm system this summer. thanks again!
Old 04-23-2008, 05:57 PM
TheJGB3's Avatar
When you get your remote at the dealer, you have to program it.
It goes like this
(make sure you have all the doors closed)
insert key in ignition, turn key to the on position press the lock button
then right away turn the key off
repeat this a few times, until you hear the locks going. Then you are done
You have to be very quick when you do this to get it to work.
If you are having trouble, They will probably do this for you for free.
Old 04-23-2008, 06:28 PM
turbo-2nr's Avatar
lol the dealer.. do it for free!! they charge almost $100 for this and it only takes a min, but they will keep your cak for 30, just program it you self
Old 04-23-2008, 06:40 PM
Dan8yourV8's Avatar
Default Re: (TheJGB3)
its under the dash on the left kick
Old 04-23-2008, 07:45 PM
jfang's Avatar
yo appreciate it guys ya i'm goin to do it by myself no way am i paying 100 bucks to get it done when it's that easy. glad i won't have to frickin unlock and unlock by key anymore.
Old 04-23-2008, 07:59 PM
BlueIntegraBoy's Avatar
Default Re: (jfang)
I just reprogrammed factory remotes on my ITR. Took a minute to do it. Can't believe the dealership charges so much.
Old 04-23-2008, 08:38 PM
TheJGB3's Avatar
I have never been charged by the dealer to program my remotes. And I have had three different Honda dealers do this for me for free. The last time they showed me how to do it so I can do it myself now. I was having trouble doing it because I wasn't doing it fast enough.
Old 04-24-2008, 04:40 AM
D50boy's Avatar
Default Re: (jfang)
You may want to look at the security section on how to make a killswitch until that alarm comes. Keep it safe
Old 05-01-2008, 11:45 AM
leblanc3's Avatar
Default Re: (jfang)
Hey guys looking to buy a remote for the stock keyless entry for my Si. From what I have read, the 99-00 EX and Si are the same FCC number??... Is this true? Cause my module reads FCC ID A269ZUA123 and all the ones I have been finding are A269ZUA106.
Old 05-01-2008, 07:17 PM
jfang's Avatar
Default Re: (leblanc3)
hey man, i jsut tried programming mine, with the 106 ending FCC ID, it unlocks (meaning it was verified) however, when i got out of the car, it doesn't work... i wonder if needs to be the other FCC Id you're talking about...
Old 05-02-2008, 01:45 AM
leblanc3's Avatar
Default Re: (jfang)
Yeah that sucks. I could only find the 106 keypads. I dont know where to find the 123's...Everywhere says that 99-00 si and ex are the same. I guess I should keep looking for the actual one. Let me know if you find out anything else
Old 05-03-2008, 11:09 AM
jfang's Avatar
does anyone have an answer for this?
Old 05-03-2008, 11:56 AM
leblanc3's Avatar
Default Re: (jfang)
X2
Old 05-03-2008, 02:06 PM
H-T White Ops
NOFX's Avatar
Here are the only keyless remote part numbers I could confirm. Of course Honda parts don't have the same part numbers on them. But this will show you which trims and years use the same exact remotes.
If it's the same part number, it's the same EVERYTHING.
TRANSMITTER, KEYLESS ENTRY CIPHER
39950-S01-A01
1996-1998 2DR EX (STD)
1996-1998 2DR DX (OPT)
1996-1998 2DR HX (OPT)
1996-1998 3DR CX (OPT)
1996-1998 3DR DX (OPT)
1998 4DR DX (OPT)
1996-1998 4DR EX (STD)
1998 4DR GX (OPT)
1996-1998 4DR LX (OPT)
TRANSMITTER ASSY., KEYLESS
72147-S04-A02
1999-2000 2DR EX (STD)
1999-2000 2DR SI (STD)
1999-2000 4DR EX (STD)
08E61-S01-101
1999-2000 2DR HX (OPT)
1999-2000 4DR GX (OPT)
1999-2000 4DR LX (OPT)
Old 05-03-2008, 04:26 PM
typeRcoupe32's Avatar
i just took a look at mine its a 99 civic cdn si, and i could not find it could they have taken it out when the last owner tried to hook an alarm up? is it close to the light modual
Old 05-04-2008, 12:22 PM
leblanc3's Avatar
Default Re: 99-00 Civic Remote Entry module location? (jfang)
So I emailed Originalkeyless.com and they said that each civci module will have a different FCC code, and that the 106 one will work for it for sure. So I would try reinstalling it again, and seeing if for some reason that was the problem. Let me know how it goes.
Old 05-04-2008, 12:58 PM
H-T White Ops
NOFX's Avatar
Like I posted above, ALL '99-'00 EX/Si trims in the US hatch the same exact type of keyless remote.
Honda doesn't use the same part number for two different parts.
Old 05-05-2008, 08:56 AM
jfang's Avatar
just to updated you, the ebay auction that i won the FOB from (every time i see fob i read it as Fresh Off Boat, random tangent) said that the FOB came off of a 2000 EX, which should work for mine. Like i said before, i hear the validation because of the lock motors going off. however afteri pull out the key and try it. nothing.
Quick Reply: 99-00 Civic Remote Entry module location?
