99-00 Civic Fog Light Install
#27
theebay fogs were oem replica had all the same **** as honda oem fogs so thats all i needed to know thanx im gunna see if i have the plug behind the fuse box i hope its there
#30
I had the same problem. This is that u do. That male connector under your hood connects to your fog light harness.. Behind your fuse box there's another connector in BLUE TAPE. Connect that to your relay.. Ground the relay then the other 2 male connectors plug into your fuse box. I think is 1 and 3.. They should turn on when your car is fully on engine running and everything.. Pm if anything..
#32
i'm pretty sure what you are looking for is the factory plug that is under the power steering resevior behind the drivers side headlight. it's tricky to locate, but it's there. it's got blue tape on it i think and it's tucked away pretty good.
cleanHONDA619
10
01-15-2017 05:10 AM
Frost7177
04-03-2008 05:52 PM
