!need a walk-thru on replacing stock pistons with high comp.!
Old 11-25-2008, 11:36 AM
howie8894's Avatar
Icon6 !need a walk-thru on replacing stock pistons with high comp.!
i've got a 93 cx shell, with a ctr jdm swap-i threw a rod... didn't damage the block... but, that isn't the problem. i figured since i'll be in there, i might as well build it up a bit-and ordered the oem high-comp pistons, valves, and springs... problem is: i have no idea what i'm doing... lol
anyone willing to offer an in-depth walk-thru...? it would be much-appreciated... thanks
Old 11-25-2008, 03:20 PM
revhardallday's Avatar
REMOVAL
  1. Remove the oil pan assembly.
  1. Remove the right side cover.
  2. Remove the oil screen.
  1. Remove the oil pump.
  2. Remove the baffle plate (B16A2 engine).
  1. Remove the bolts and the bearing caps. CAUTION: To prevent warpage unscrew the bolts in sequence 1/3 turn at a time, repeat the sequence until all bolts are loosened.
  2. Remove the rod caps/bearings and main caps/bearings. Keep all caps/bearing in order.
  1. Lift the crankshaft out of the engine, being careful not to damage journals.
  2. Remove the upper bearing halves from the connecting rods and set them aside with their respective caps.
  3. Reinstall the main caps and bearings on the engine in proper order.
  1. If you can feel ridge of metal or hard carbon around the top of each cylinder, remove it with a ridge reamer. Follow the reamer manufacturer's instructions. CAUTION: If the ridge is not removed, it may damage the pistons as they are pushed out.
  1. Use the wooden handle of a hammer to drive the pistons out.
  2. Reinstall the connecting rod bearings and caps after removing each piston/connecting rod assembly.
  3. Mark each piston/connecting rod assembly with its cylinder number to avoid mix-up on reassembly. NOTE: The existing number on the connecting rod does not indicate its position in the engine, it indicates the rod bore size.
AssemblyNotesBefore installing the pistons, apply a coat of engine oil to the ring grooves and cylinder bores.
  1. If the crankshaft is already installed:
    B16A2 engine: 40 Nm (4.1 kgs.cm, 30 ft.lbs.)
    D16Y5, D16Y7, D16Y8 engines: 31 Nm (3.2 kgs.cm, 23 ft.lbs.)
    1. If the crankshaft is not installed:
      NOTE: Maintain downward force on the ring compressor to prevent the rings from expanding before entering the cylinder bore.
      © 2008 ALLDATA LLC. All rights reserved.Terms of Use
      Old 11-25-2008, 03:23 PM
      Resident Gearhead
      BryanM.'s Avatar
      Great post
      Old 11-26-2008, 08:59 AM
      howie8894's Avatar
      thank you... much appreciated...
      RITLINBOY-91.SI
      07-10-2012 08:57 PM
      speedyclack
      03-16-2010 01:36 PM
      6ghatch
      12
      01-05-2005 04:55 PM
      jdmsijdm
      03-31-2004 02:49 PM
      Ignitecivic
      09-08-2003 05:09 PM
      Quick Reply: !need a walk-thru on replacing stock pistons with high comp.!
