98 Honda Civic ex not starting
Need everyone's help out with this one!
Its a 98 Honda Civic ex. The car is automatic. The car was driving fine. When I braked the car just turned off randomly. Car doesn't start now. It's turns over but does not start. It has no spark and not recieving fuel to the filter. We changed the distributor, fuel pump, ecu, fuel pump relay, checked the fuel pump fuse under the dash. Checked motor oil. Car is still doing the same thing. I am out of ideas and in need of help!! If anyone has ideas please let me know. I'm super confused what else it can be.
Thank you
Thank you
Re: 98 Honda Civic ex not starting
When you turn the ignition 2 clicks it supply power to the starter fuel pump various other parts etc.. you could have a broken or clogged fuel line but that only answers the no fuel still then you have no spark if I had to guess I think you have a bad or broken connection somewhere in one of the engine harnesses and
I also believe there is a clog in one of the fuel lines. I am going to have a better look at it. Check under the car etc. I will check the harness to see if maybe a wire broke somewhere or something came loose.
PapaMoose
60
10-13-2011 01:46 PM
4doorcivic9
06-11-2008 06:31 AM
punkkid12o3
Honda Civic (2001 - 2005)
02-05-2008 08:36 PM
Cameron60
01-16-2007 06:04 PM
