98 ex d16y8 Wiring harness work in a 98 lx d16y7? - Honda-Tech
Old 02-07-2012, 06:14 PM   #1
Default 98 ex d16y8 Wiring harness work in a 98 lx d16y7?
Soooooo.... I need a main harness that runs under the dash, from fuse box to fuse box (not the engine harness) and Im only finding EX D16y8 harness on fleabay and I have d16y7. Will these harnesses cross over? I really need to get this car back on the road and this harness is to ate up to repair.
Thanks for your fast replies,
Craig
craigtrofc is offline   Reply With Quote
Old 02-07-2012, 07:19 PM   #2
canadaek's Avatar
Default Re: 98 ex d16y8 Wiring harness work in a 98 lx d16y7?
i'm fairly sure there the same harness only the engine harness was different . (as long as they match auto+auto manual + manual ) you can convert the auto to work in a manual car but it's more work.
canadaek is offline   Reply With Quote
Old 02-08-2012, 04:38 AM   #3
I have an auto, and this harness is out of an auto. Im am not looking at doing any changes on any harnesses. I just want to plug and play. I chase wires all day at work and I really am tired of doing it at home. :D
Old 02-08-2012, 05:21 AM   #4
Seagull Management
94EG8's Avatar
You wont have a plug for the secondary O2 sensor
94EG8 is offline   Reply With Quote
Old 02-08-2012, 06:43 AM   #5
Ok, Ill keep looking for an LX y7 harness.
Old 02-08-2012, 09:16 AM   #6
Wait. The harness I am asking about is under the dash and connects to the engine harness and under dash fuse box. An EX auto harness SHOULD cross over?
Old 02-08-2012, 03:09 PM   #7
canadaek's Avatar
secondary o2 on a y7 is under the hood on the engine harness .
Old 02-09-2012, 04:51 AM   #8
Ok, I replaced that harness already. hrm. Im thinking Im gonna have an issue finding this harness used.
99 d16y8 to 98 d16y7 Josh1999Civic Honda Civic / Del Sol (1992 - 2000) 8 11-25-2015 06:53 PM
VTEC wire harness problem with d16y8 FRKWOO Honda Civic / Del Sol (1992 - 2000) 5 09-14-2008 10:00 AM
Will 96-98 GSR harness work for a D16y8 tshuajzoo559 Honda Civic / Del Sol (1992 - 2000) 3 06-02-2008 07:06 AM
98 D16y8 Auto to 99 D16y8 5-Speed Swap Wire Harness Issues???!! MilanoRed_EJ8 Honda Civic / Del Sol (1992 - 2000) 5 03-08-2007 11:29 AM
WTB- 96-98 EX harness, Z6 distributor, y8 I/M Timmay Want to Buy 1 07-30-2005 03:38 PM
Tags
2000, 98, automatic, civic, d16y7, d16y8, engine, harness, honda, hx, lx, manual, motor, wiring, work, y7
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
