98 Civic w/ b18b1 swap, CEL for CKP.
Old 06-09-2015, 06:24 PM
SpoonfedCivic's Avatar
Default 98 Civic w/ b18b1 swap, CEL for CKP.
Hello,
98 Civic with B18B1, I've converted to an OBD1 P75 using a OBD2 to OBD1 jumper harness. I have a CEL error code 4 which is CKP, do I need to do the CKP fix where you cross the wires at the ECU to get the signal from the dizzy instead of the sensor by the crank pulley? Thanks.
Old 06-09-2015, 11:47 PM
carlos8's Avatar
Default Re: 98 Civic w/ b18b1 swap, CEL for CKP.
No you have a OBD1 ECU that not look for the crank fluctuation sensor.
The code 4 is the CKP inside the distributor. Check for continuity to body ground at B15 and B16 ECU pin, Then check for resistance on the same b15 and b16 (350-700 ohms) is the Honda specs.
Old 06-10-2015, 02:16 AM
Technical Hero
HondaPartsHero's Avatar
sikcrx80
05-01-2023 05:16 PM
BradEK9
05-14-2014 05:50 PM
max_fixed
37
03-29-2013 06:09 AM
Lou845
07-11-2012 02:53 PM
2ndteg2turn9sec
05-18-2012 02:16 PM
Quick Reply: 98 Civic w/ b18b1 swap, CEL for CKP.
