98 civic lx - coolant leak and blinking CEL
Old 11-25-2012, 04:20 PM
chriss84's Avatar
Default 98 civic lx - coolant leak and blinking CEL
okay so my check engine light came on the other day took the car to AutoZone it showed the code p0303 cylinder 3 misfire. The next day drove the car for thanksgiving on the way to dinner a hose busted under the hood dumping the antifreeze and overheating the car. Anyways I replace the hose, check engine light went off car drove fine didn't seem to have an issue. Then Saturday drove 40 minutes north then back just fine before I got home I stopped at the bank and there was smoke coming out under the hood similar to where I replaced the hose. The check engine light came back on this time it was blinking. I replace the thermostat and the plugs the light seems to blink sometimes and stay solid sometimes. This time the codes were p0300, p0302,p0303,and p0705. I am stuck here trying to figure this out. It doesn't show any obvious signs of a head gasket but I'm not sure where to look?
Old 11-25-2012, 04:31 PM
Former User's Avatar
Default Re: 98 civic lx please help!!!
Post pictures where you see smoke coming from. Fix any coolant leak you find.
Also replace the plugs, plugs wires, cap, and rotor. Then go from there.
Recheck this code: P0705. Is it actually P0715?
Old 11-25-2012, 04:52 PM
chriss84's Avatar
okay so i cant figure out how to upload the pic the leak/smoke seemed to be coming from around the thermostat area. the u shaped hose is the one i replaced also. the car has been idling a little rough at times also. and that code says p0705 for sure not sure if the guy at autozone put it in wrong or what but thats what i got. all noticable leaks have nbeen fixed.
Old 11-25-2012, 04:53 PM
You will find instructions for posting pictures in the Rules sticky.
You can jump the service connector to pull both CEL and transmission codes - see Codes sticky.
Old 11-25-2012, 04:54 PM
chriss84's Avatar
also distributor is brand new as the cap and rotor. my upper radiator hose broke about a week ago is it possible antifreeze could have worked its way in the distributor since it sits right next to it?
Old 11-25-2012, 04:56 PM
Could be. Open it up to see.
Old 11-25-2012, 04:58 PM
chriss84's Avatar
this all started after I replaced the radiator cap the seal was torn up so I put a new one on and all hell broke loose
Old 11-25-2012, 04:59 PM
chriss84's Avatar
inside the cap looks fine.
Old 11-26-2012, 07:03 AM
EGxBoostFiend's Avatar
Default Re: 98 civic lx - coolant leak and blinking CEL
How hot did your car get? My last engine got really hot and ended up warping the head. It leaked like hell.
steveo514
Honda Civic (2006 - 2015)
09-12-2018 05:32 AM
alfiler
02-16-2009 11:55 PM
clubef9
07-03-2007 07:57 AM
Seks
08-09-2005 12:00 PM
Gsr94black
09-02-2004 09:00 AM
Quick Reply: 98 civic lx - coolant leak and blinking CEL
