98 civic ex, no spark
So my car was running fine for a while until the other day it just died on me after going through a light. I attempted to start up again, failed. It cranks and turnsover but didn't start. I had a somewhat similar problem previously (months ago) where my car wouldn't start or turn over in which I ended up having the distrib cap & coil replaced. The only thing that was changed recently was new spark plugs.
Anyhow, a buddy of mine works on Honda's and after talking to him, he told me to test a few things. When I put my key into start pos 2, I only hear 1 click from the fuel pump relay but also my check eng light says on. My friend says i'm supposed to hear 2clicks in that key position. I tested to check if the fuel pump primes, I can hear it whenever I turn the key to pos2 (without attempting to start). I tested the spark plug connector (along with someone else) and determined I'm not getting a spark. I can smell the gas & i can hear the fuel pump so i know gas it getting there. I've also tested the fuses under the dash, all of them checked out ok. So after all this I was told more than likely it's my Fuel Pump Relay? Either that or timing belt is broken (which I'm hoping isnt the case) Has anyone had any similar probs, thoughts or suggestions as to what could be the cause? The only ting I haven't tried yet is to try resetting the ecu, but my friend is convinced its the relay b/c i'm not getting more than 1 click and my chk eng light stays on. Any Ideas?
Re: 98 civic ex, no spark
Could be your igniter that is bad.
If you are getting fuel then it is not the pump or main relay.
Try starting the car several times then pull a spark plug and if it is wet then you are getting fuel.
The fact that when the key in put into start pos II, we're only getting one click and check eng light stays on, would you think the relay would cause something like that? I havn't attempted to reset the ecu yet but that's the next step I was going to take.
I would check the ICM. They problem is definitely lack f spark, so its likely something with the distributor. It's got to either be the ignitor (ICM) or the coil pack.
slavagc8
15
05-26-2009 06:17 AM
