98 civic ex Idle air control valve problem! Which plug do I plug it into?
Old 06-04-2009, 11:01 PM
esurds's Avatar
Icon2 98 civic ex Idle air control valve problem! Which plug do I plug it into?
Hey Ive got a civic with a 98 civic ex auto engine harness in it and I did a D16Z6 swap into it and the only thing I have to do is hook up the idle air control valve. Does anyone know which plug of what color wires i need to be able to hook it up? Let me know. Thanks
Old 06-04-2009, 11:38 PM
Ruben19's Avatar
Default Re: 98 civic ex Idle air control valve problem! Which plug do I plug it into?
i member they're 2 plugs that are the same. just plug them and find out or get a repair manual
Old 06-05-2009, 02:13 AM
HCivExoo's Avatar
what happened to the Y8?
Any way, you may want to consider putting the IM from your Y8 on your Z6. It is a better manifold than what comes on the Z6 and it allows you to run the three wire IACV that is under your throttle body on the Y8. Other wise you would have to run a two wire on the Z6 and i am not sure how to do that while still using the auto ecu.
the wires should be orange, Black with yellow and i can't remember the other color.
Old 06-05-2009, 06:07 AM
Former User's Avatar
The 98 D16Y8 with a MT has a 2-wire IACV (YEL/BLK, BLK/BLU wires), whereas the AT has a 3-wire IACV (YEL/BLK, BLK/BLU, ORN wires).
Old 06-07-2009, 06:23 PM
esurds's Avatar
Hey that's actually really helpful. I have a auto harness that all I need to do is hook up that one plug. Do you know know how to hook up the auto to a manual one? Thanks
Old 06-08-2009, 04:12 PM
esurds's Avatar
Hey do you know how to hook up the auto to the manual? Do you know where I can look to figure it out? Thanks for the help
Nisif
10-03-2014 02:39 AM
curioso
02-07-2010 09:21 PM
96jdmciv
10-29-2008 04:25 PM
civicmatt
07-05-2003 07:45 PM
Hatebreed215
01-17-2003 08:26 PM
Quick Reply: 98 civic ex Idle air control valve problem! Which plug do I plug it into?
