98 Civic EX climate control back lighting?
Old 03-21-2014, 10:30 AM
Cheapshot1979's Avatar
Default 98 Civic EX climate control back lighting?
Are the '98 EX's supposed to have back illumination for the temp slide, and fan selector switch? I have to turn on my dome light in the dark to adjust between cold/heat temps and fan speed.
Old 03-21-2014, 10:48 AM
Fish Twig
tony_2018's Avatar
Default Re: 98 Civic EX climate control back lighting?
bulbs are probably burnt or you're not getting any power to them or its not receiving a signal from your switch.
Old 03-21-2014, 10:57 AM
Former User's Avatar
Do the cluster back lights and parking lights work?
Old 03-21-2014, 11:54 AM
Yes, cluster and all other lights work, just no lighting behind the temp slide and fan switch. Since I bought the car they haven't worked, so I assumed there was no back lighting in that location. Anyone of you know off the top of your head what bulb size it would be? If not I'll just pull it out and get the number off the bulb(s).
Old 03-21-2014, 11:58 AM
Before replacing the bulbs, you could check voltage at Red/Blk wire and ground at the Red wire in the climate control connector.
Old 03-21-2014, 07:47 PM
okay
prodjay10
Honda Civic (2001 - 2005)
05-22-2015 10:29 PM
charles1
02-01-2008 10:45 PM
bmanuhutu
05-14-2007 10:47 AM
T_bones
11-03-2005 01:49 PM
slipstream2005
02-05-2005 04:01 AM
Quick Reply: 98 Civic EX climate control back lighting?
