98 civic CHECK ENGINE LIGHT FLASHING - Honda-Tech
Old 02-16-2009, 08:57 PM   #1
New User
Default 98 civic CHECK ENGINE LIGHT FLASHING
my car was running fine after i had changed the spark plugs, and cap and rotor, then the next day i was driving on a rainy day and then the check engine light came on, then the check engine light started flashing, then the speedometer started jumping up and down, and all the electrical lights seem to dimmer on and off. can someone please give some tips on how to fix this problem? thanks.
alfiler is offline   Reply With Quote
Old 02-16-2009, 09:02 PM   #2
ifIexplode's Avatar
Default Re: 98 civic CHECK ENGINE LIGHT FLASHING
A blinking check engine light usually indicates a misfire code.
Check the FAQ about jumping the service connector to pull the codes.
ifIexplode is offline   Reply With Quote
Old 02-16-2009, 09:50 PM   #3
DC2-ProdUcTiOnS's Avatar
Location: Howcome we park on driveways, and drive on parkways?
its your motor saying to you, WHAT HAVE YOU DONE!?! YOU CHANGED ME NOW IM GOING TO SELF DESTRUCT! hehehe...sorry its late...
DC2-ProdUcTiOnS is offline   Reply With Quote
Old 02-16-2009, 10:14 PM   #4
mortificationrock's Avatar
Quote:
First things first. Read the codes and find out what they are. There is a Cel Faqs at the top of the forum. After you do that and have the codes check what they are and get back to us if you cant figure it out.
mortificationrock is offline   Reply With Quote
Old 02-17-2009, 12:38 AM   #5
sublime423's Avatar
what kind of plugs?
sublime423 is offline   Reply With Quote
Old 02-17-2009, 12:40 AM   #6
99EK-T's Avatar
Iv seen the CEL flash before but never dim all the lights, check it out im interested what caused it
99EK-T is offline   Reply With Quote
Old 02-17-2009, 12:42 AM   #7
New User
ngk platinum plugs
Old 02-17-2009, 12:55 AM   #8
sublime423's Avatar
if it never happened before the "tune up" recheck your work. tight connections, plug gap, ect...I have seen cheap caps and rotors cause headaches before
check engine none stop flashing 98 civic Hondaiii3 Honda Civic / Del Sol (1992 - 2000) 4 10-07-2011 10:33 PM
What CEL code is being thrown? strider380 Honda Civic / Del Sol (1992 - 2000) 3 11-15-2010 08:39 AM
My ECU LED does'nt flash Dachdu 92 Honda Prelude 4 09-21-2010 05:30 AM
94 honda accord D4 Light Flashing Joserey90 Honda Accord (1990 - 2002) 11 09-17-2010 07:12 PM
flashing engine check light katie Honda Accord (1990 - 2002) 6 12-09-2002 07:44 PM
Tags
1996, 96, 98, blinking, check, civic, coupe, engine, flash, flashing, honda, light, lx, mean, service, speedometer
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
