97 Honda Civic key stuck in ignition, no start and sparks.
trying to help a friend here, says he has a 97 honda civic auto, and recently he's been having this problem with the key getting stuck in the ignition after he turns it off. the key wont come out at all, even after its put in park and the only way he can take it out is by disconnecting the battery negative cable, the key is original too. so they replace the ignition assembly with new key and all, and everything was working, but then he said he got a small spark from the underdash fuse box when he touched something and well now the car wont start unless you jump the starter. whats weird is that when everything is plugged in, i can touch around the steering column area inside the car and ill get a spark shooting off like its grounding off. anyone have any idea on whats going on, and what i should look for?
Re: 97 Honda Civic key stuck in ignition, no start and sparks.
<p>Second party threads usually don't go well because info gets lost traveling from your friend to you and then to us. You should ask your friend to post in this thread.</p><p>Is the key still getting stuck in the ignition? Or is that problem fixed?</p><p>Does the fuel pump prime? Any CEL codes?</p>
Frost7177
06-27-2009 12:28 PM
