97 Civic has idle and starting problems - Honda-Tech
Old 02-14-2014, 06:31 AM   #1
Default 97 Civic has idle and starting problems
I have a 1997 civic LX with the d16 with the throttle body that points straight up. I changed the plugs, wires, O2 sensors, alternator and battery so far to no avail. Its only on cold start and idles fine when it warms up. I also find that turning the key and waiting for the fuel pump to build pressure and turn off then repeat the key stroke and it turns right on, if I don't, it doesn't start. I think its a fuel issue, but I don't want to keep replacing **** that doesn't help. Fuel filter is going to be replaced asap.
Fuel filter changed, timing is fine. there is currently 7 codes being thrown:
p1298
p0135
p0141
p0301
p0302
p1300
p1399
attz0r is offline   Reply With Quote
Old 02-14-2014, 06:38 AM   #2
Default Re: 97 Civic has idle and starting problems
Thank you for making a thread, wasn't sure if I could with no posts.
Old 02-14-2014, 12:10 PM   #3
chillerice's Avatar
I have kind of a similar issue with the cold then when warm it idles okay... Check that your ignition timing is not off and do a rotor and cap change... If it cranks but not start it could be ignition related.
In my case I think I wet my dizzy and moisture caused it to bog,idle bad and sometimes die when the idle drops to 0. Replacement motor coming though. Had a rod knock last summer.
chillerice is offline   Reply With Quote
Old 02-14-2014, 01:20 PM   #4
marcelosm's Avatar
Any CELs?
marcelosm is offline   Reply With Quote
Old 02-14-2014, 08:50 PM   #5
The light isn't on but when I told it for emissions, it threw 5 codes, O2 sensors (both), speed sensor, cylinder #1 missfire and one misc one. O2 sensors were changed and I reset the ecu, been at work all day and havent had a chance to see if it comes back.
It seems everyone thinks I should check timing, so that will be tomorrow.
Old 02-15-2014, 05:03 PM   #6
p1298
p0135
p0141
p0301
p0302
p1300
p1399
It has both brand new O2 sensors. The one thing that really effects the idle is resetting the ecu while its idling, it goes to a smooth normal idle, not a choppy nasty idle. I'm thinking it has a bad ecu or bad wire somewhere. any suggestions?
00 EX w/ GSR swap, no ECU or Fuel Pump power, and yes I searched Sparky2001 Honda Civic / Del Sol (1992 - 2000) 17 08-05-2016 04:04 PM
car stalls at a stop tekstyle Acura Integra 15 05-10-2015 12:10 PM
92 accord trouble starting and hesitation/stalling help wanted Honda Accord (1990 - 2002) 9 05-01-2015 02:30 PM
87 civic si cranks but wont start MFH87CivicSi Classic Hondas 15 02-02-2010 12:09 AM
Code 16 Problem...!!! Baserloks Honda CRX / EF Civic (1988 - 1991) 6 06-02-2009 11:57 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
