97 civic ex high beams not working - Honda-Tech
Old 05-29-2011, 11:02 AM   #1
Default 97 civic ex high beams not working
i took my new to me 97 ex through a car wash last night, on my way home i went to use the high beams, and they turned a real bright purple and went off. the fuses are good and i have not found the relays yet. i have not checkout the bulbs either, but i don't think they would both burn out at the same time. the low beams still work fine.
90, 91 miata is offline   Reply With Quote
Old 05-29-2011, 11:36 AM   #2
Default Re: 97 civic ex high beams not working
check your bulbs...next weakest link
vitamin_c95 is offline   Reply With Quote
Old 05-29-2011, 11:46 AM   #3
Linked's Avatar
if the bulbs were damaged, both hi and low beams wouldnt work.
also both sides typically dont go out together if it was a problem with the bulb
its probably raining in indiana though, cause i;m next door in chicago and its pouring down
but the most important thing other than the bulbs is checking if you have voltage at the the connector
Linked is offline   Reply With Quote
Old 05-29-2011, 11:50 AM   #4
i forgot hondas are single bulbs. I actually watched a few bulbs turn purple before blowing. Good point tho
Old 05-29-2011, 12:21 PM   #5
Quote:
im going to in a few
Quote:
thats what i thought but idk
its 92 and sunny all week!
thanks i will look into this any one know where the relays are for the head lights? im going to check the voltage befor the relay also.
i have seen that to, but i dont see why they would both do that at the same time.
thanks all i will check them out later and any one know where the relay is for the high beams just so i can rule them out
Old 05-29-2011, 07:02 PM   #6
There's no relay in the circuit.
How did you check the fuses for the high beams? Which fuses did you check?
Former User is offline   Reply With Quote
Old 05-30-2011, 08:58 AM   #7
Quote:
really?
there are 4 different fuses under the dash two for each high beams and low beams.
Old 05-30-2011, 09:00 AM   #8
Yes, really.
Quote:
My question is what method did you use to check the two high beam fuses. The most reliable way is to test for voltage to body ground from both top test tabs of each installed fuse with the light switch on. Click the Fuses link in my signature.
Old 05-30-2011, 10:24 AM   #9
the fuses i use are clear and you can see if the are blown or not?
it turned out that the light bulb filament for the high beams burnt out so i will be replacing them later. i have never seen both high beams on a car burn out at the same time before.
Old 05-30-2011, 10:28 AM   #10
Visual inspection of fuses can be unreliable and also does not tell you whether the fuse gets voltage from the battery. But I'm glad to hear that you solved the problem.
Old 05-30-2011, 10:48 AM   #11
thank you, i will check that out
how do you all fill about yellow headlight bulbs in a civic? i know in some cars that don't produce enough light out put bc the way the headlights are made but in some car the work just fine.
honda accord 2008. my right low beam works when i take right high beam fuse out. why? Tahir Karamat Honda Accord & Crosstour (2003 - Current) 1 11-06-2016 04:53 PM
headlight issues FML shocker911 Honda Civic / Del Sol (1992 - 2000) 3 03-02-2010 02:53 PM
High beams work low beams do not eghatchin Honda Civic / Del Sol (1992 - 2000) 16 04-25-2008 05:46 PM
why would low beams not be working, but the high beams are??? stupidsn87654 Lighting 3 09-08-2007 08:27 PM
1993 accord headlights chochocho Honda Accord (1990 - 2002) 5 01-06-2005 10:49 AM
Tags
1997, 2000, b18c, beam, beams, civic, dx, ek, headlights, high, honda, part, purple, stop, time, weakest, work, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
