97 Civic ex front Camber - inner tire wear problem
Hi i have an issue were the inner tires wears out within 4 months. I put New (Stock Height) complete struts, springs, mounts, ball joints (lower & upper ) upper contol arm plate, sway bar links, tie rods inner & outer still no luck 4 diffrent alignment shops they always say its within spec . Is there a camber bolt or something that can be added or what to do? Thanks
Cool Cool Island Breezes. BOY-EE
Re: 97 Civic ex front Camber - inner tire wear problem
You may have a torn bushing in a control arm or something. Are the front or rear tires wearing that way? No...there aren't camber bolts for 88-00 civics.
Nothing modified its all stock toe and camber according to alignment specs are with in . The rear i have adjustable upper and dont get any tire wear all tho lower one i cant adjust cause bolt is frozen in and will break so i cant adjust toe at rear unless a cut a piece from frame so i could put a bolt and nut there with adjustable lower.
EnjoyTheRideDC2
03-02-2006 04:05 AM
Jason C SBB
12-29-2003 08:34 PM
