93 Civic Hatch/JDM B16A stock engine -- No vtec no CEL
Old 12-19-2014, 09:37 PM
Billet0614's Avatar
Default 93 Civic Hatch/JDM B16A stock engine -- No vtec no CEL
93 Civic Hatch JDM B16A stock engine. I believe its the original harness to the car. P28 ECU socketed P30 base map chip Hondata S100. this is the first time it has run since socketing the ECU. I am able to jump the pressure switch and power up the solenoid and makes a change to the idle. I have tried a different pressure switch. Grabbed one from the junkyard. I'm not sure where I should be headed I'm thinking its going to be a problem in the harness. are there any common problems I should be looking at first? any advice would be helpful.
Old 12-20-2014, 01:26 AM
Technical Hero
HondaPartsHero's Avatar
Default re: 93 Civic Hatch/JDM B16A stock engine -- No vtec no CEL
Try another working ECU to rule that out.
Old 12-20-2014, 04:42 AM
Former User's Avatar
Post the CEL codes
<--- Assumes CEL doesn't work
Old 12-20-2014, 07:52 AM
e0325's Avatar
Are you sure the car is wired for vtec? I believe only the 1993 si hatch came prewired. I think hondapartshero sells the vtec wiring that connects into the plug for the ecu
Old 12-20-2014, 11:22 AM
Billet0614's Avatar
Default Re: 93 Civic Hatch/JDM B16A stock engine -- No vtec no CEL
Yes the CEL works I have pulled codes out of it before had bad IAT and burnt transistor in old ECU for purge control I believe (fixed). I would try another ECu if I had access to one.
Old 12-20-2014, 11:23 AM
Billet0614's Avatar
it is worth checking to make sure this ECU is set up for vtec and I have no wiring problems.
Old 12-20-2014, 11:24 AM
Billet0614's Avatar
Its ok to be using a USDM ECU with a JDM motor right?
Old 12-20-2014, 11:29 AM
Originally Posted by Billet0614
Yes the CEL works
Right now, if you turn the key from OFF to ON(II), does the CEL turn on and then off after 2 seconds?
Old 12-21-2014, 07:43 AM
Billet0614's Avatar
Yes the CEL comes on for 2 then off no codes tried again. I back probed solenoid side of the vtec solenoid connector it will send a 13v signal but not until 5500-6k and still nothing. the car seems to be struggling to make power above 4k and on my last test drive I was able to reach 6500 rpm in 1st gear to only 3k when I was almost back to the shop. im really lost and I have nothing to point me in the right direction it seems like.
Old 12-21-2014, 05:09 PM
CivicEJ041412
05-27-2012 07:51 AM
sethmoman
21
01-12-2012 08:33 AM
turboedturbo
21
01-29-2011 07:27 AM
BigBoulda
03-22-2008 04:45 PM
Quick Reply: 93 Civic Hatch/JDM B16A stock engine -- No vtec no CEL
