97 civic cranks wont run, no spark, no injector pulse, PLEASE HELP
Old 09-25-2011, 06:27 PM
AaronDavis's Avatar
Default 97 civic cranks wont run, no spark, no injector pulse, PLEASE HELP
Hello,
I want to say thanks in advance for any help or advise given.
I bought a 97 civic ex 4 door that had a b16 swapped. 5 speed transmission, 0bd1 computer, obd2a engine harness with jumper. I already had a 99 civic dx hatchback with a d16y7 in it. completely stock. I wanted to swap engines between the car. I pulled the b16 with tranny, harness, ecu, axles, etc. and pulled the same from the hatchback. I put the d16, automatic transmission, shifter, pedal assembly, engine harness, ecu, axles, and such into the 97 and noticed there was a plug to the ecu missing, but it started and ran, shifted and all just fine BUT the speedo, odometer, tach, cooling fan, and communication with dlc did not work(probably more but thats what I noticed). I did some research and found that the obd2a cars had the missing plug as part of the engine harness and the obd2b cars had it as part of the main harness that runs through the dash. I ordered an engine harness from a 97 civic dx auto and all plugs were there, everything went in and connected perfectly except the distributor. researched some more and found 96-98 distributor is different than the 99-00 distributor. I got a distributor and now the car wont start. It has no spark, no fuel injector pulse, and no fuel pressure. I saw that the cylinder position sensor, crankshaft postition sensor, and top dead center position sensor is in the distributor, which I assume is what decideds when to spark and when to pulse. I have not tried another ecu yet but I read that the p2e is for 96-00 so I didnt think it would change anything. The distributor does have power to it on the ignition input signal wire (think black/yellow wire)
The car still wont start. Im going crazy trying to figure this out.
PLEASE HELP!
Thanks again very much,
Aaron
Old 09-25-2011, 06:34 PM
Former User's Avatar
Default Re: 97 civic cranks wont run, no spark, no injector pulse, PLEASE HELP
The 97 Civic is OBD2a and the 99 Civic is OBD2b.
Old 09-25-2011, 06:37 PM
AaronDavis's Avatar
yes, which is why i switched the engine harness and distributor
Old 09-25-2011, 06:45 PM
What ECU is now in the 97 Civic?
Old 09-26-2011, 04:00 AM
AaronDavis's Avatar
p2e, its the one from the 99 but I found it said it fits 96-00 civic automatics or something like that.
Old 09-26-2011, 05:40 AM
The 99 Civic is OBD2b. Why are you using an OBD2a engine harness from a 97 Civic?
Old 09-26-2011, 09:44 AM
AaronDavis's Avatar
because it's in a obd2a car, connector A in an obd2a car is part of the engine harness. In an obd2b car, its part of the main harness (runs through the dash). This connector has the speedometer, tachometer, odometer, o2 sensors, data link connector, and fan controls on it.
BUT you already helped me fix the car, i went to the junkyard and got an obd2a ecu and it starts and runs, just havent done a test drive yet.
Thanks again,
Aaron
Old 09-26-2011, 11:00 AM
Glad to hear you sorted out the problem.
Old 12-08-2020, 04:04 PM
Sufyan Ahmed's Avatar
Icon5 Re: civic 98 sedan no card pulse problem in distributor
any one know this fault? how i can resolve this fault? all distributor wiring ok BLK/YEL wire 12V ok
tachometer pulse not showing BLU wire in distributor...
YEL/GRN wire card not showing pulse in distributor...
injector pulse ok..
please help anyone guide me...
Thanks
Old 12-09-2020, 11:55 PM
Douglas Galeano's Avatar
Default Re: civic 99 sedan no card pulse problem in distributor
injector pulse ok..
Thanks
bcm0529
08-27-2017 05:43 PM
ThrowSomeDs
04-17-2011 04:14 PM
Outlaw-Hondaz
14
07-07-2010 02:18 PM
shyxboy
05-19-2005 01:41 PM
endless_pain
03-25-2005 11:38 AM
Quick Reply: 97 civic cranks wont run, no spark, no injector pulse, PLEASE HELP
