96 Honda Civic Window Problems
Old 11-01-2015, 12:35 AM
Matthew98DX's Avatar
Default 96 Honda Civic Window Problems
Okay so on my 96 Honda Civic Coupe, the passenger window will not work, meaning will not go and up down
First thing I predicted was the window regulator was bad, so I ordered one just in case. Well after I put it on, window still didn't work
I checked both fuses & relays (under the dash & under the hood)
Borh were good.
So i ran a wire from the battery straight to the regulator connector, to test it and that worked, it made it go up and down. (Because when I put the window regulator back in, window was half way down so I needed it to go back up)
So I'm still trying to figure out why the window switch won't work.
Old 11-01-2015, 12:49 AM
I never narc'd on nobody!
NotARaCist's Avatar
Default Re: 96 Honda Civic Window Problems
Does it not work regardless of which switch you use? Do you own a voltmeter? Have you checked to make sure the lock isn't on?
Old 11-01-2015, 02:22 AM
oneheadlight's Avatar
Borh were good.
I agree you need to check the wiring into the door and into the motor and switch. On mine it was over time, opening/closing the door, the wiring frayed and that caused no connection to the power window motor. Running new wiring fixed it. It was the ground wiring to the motor that was bad in my case. I made sure to add more wiring for less stress on the wiring in the future.
Old 11-01-2015, 03:49 AM
djedd's Avatar
If the problem still exists if the wiring is sorted.You also want to get the switch itself checked out as it gets worn out over the years and the connectors inside dont make contact with each other.If the switch can plug out, test the window with another working window switch.
Old 11-01-2015, 12:05 PM
Former User's Avatar
Check for broken wires in the door jamb connectors.
Old 11-01-2015, 01:13 PM
^^ x2, yup that's where mine was bad in the door jamb/door connector wiring area. I should have added that in my post.. but door wiring I figured was close enough
Old 11-01-2015, 04:44 PM
joshuastrauss3's Avatar
x3 check the wiring in the driver's door jamb thats the most common spot for broken wires!
Old 11-01-2015, 11:20 PM
What should I be looking for ?
Sorry if I ask dumb question lol
Old 11-02-2015, 06:30 AM
Old 11-02-2015, 07:15 AM
Fish Twig
tony_2018's Avatar
Definitely sounds like broken wires.
Old 11-02-2015, 11:11 PM
Still can't find the problem. Ugh, this so is frustrating
Old 11-02-2015, 11:26 PM
yup it takes time to trace the wiring and find the wire that is the problem. use the above wiring diagram, it will tell you the color of the power and ground of the wiring to the window's motor.. then look through for that wire. It's tedious but that's electrical work for you..
Old 11-02-2015, 11:34 PM
it's so small I can't zoom in on it to see the picture bigger
Old 11-03-2015, 05:16 AM
Fish Twig
tony_2018's Avatar
Time and patience, if anything i would look into remove the entire door harness from the door so that its easier to inspect.
Old 11-03-2015, 11:46 AM
djedd's Avatar
Matthew98DX why not just test the wires with a multimeter.
1.Do a test from your master swith connector to the fusebox and
2.From the passenger switch connector to the fusebox.
Or just run a new wire from the fusebox or master switch like oneheadlight did.
I uploaded a few images I hope it can help you out.I think you already have 2 or 3 of them, I'm guessing you do have your manuel.
Let us know what was wrong when you get it sorted.
Old 11-03-2015, 11:52 AM
NotARaCist's Avatar
..."So small"? It's the size of a piece of paper. It's not even remotely small.
Old 11-03-2015, 01:01 PM
djedd's Avatar
True.I can zoom/read the image perfectly.
it's so small I can't zoom in on it to see the picture.
bigger
Try to save the images and then open it up.Are you using a computer or mobile phone?
Old 11-03-2015, 01:10 PM
djedd's Avatar
NotARaCist I think what he means by small is that the resolution of those images are big making the layout very small.
Think of it like printing an size A2 image on a A4 paper.If he can save the image he will be able to zoom in on it though.
Old 11-03-2015, 01:14 PM
NotARaCist's Avatar
right click -> open image in new tab, if it isn't big enough. This is literally internet 101.
Old 11-03-2015, 01:22 PM
djedd's Avatar
Have mercy my friend
Old 11-03-2015, 11:00 PM
I'm checking the forums on my iPhone
I found the problem I think...
I checked the connector in the door jam, and one of the wires was out of the connector
it's blue wire with orange stripe in it
Old 11-03-2015, 11:03 PM
Thank you for including the picture where it shows which wire goes where on the connector.
Old 11-04-2015, 12:22 AM
NotARaCist's Avatar
Why do I even bother anymore?
Old 11-04-2015, 02:52 AM
yup both images that djedd and notaracist posted up show that the blu/orn, or the blue/orange wiring is for the passenger side window switch. Yup, you found it. see? told ya to check the wiring
Old 11-04-2015, 02:53 AM
ahhh don't be like that.. there there.. it'll be ok.. we know you're trying to help!! there.. a beer and a hug.. it's going to be ok little camper
Quick Reply: 96 Honda Civic Window Problems
