96 Del Sol driver door won't unlock or open
Old 04-07-2011, 03:53 PM
walternate's Avatar
Default 96 Del Sol driver door won't unlock or open
The driver door is stuck locked and I can't open it or unlock it from the inside or the outside. Already tried taking the door panel off but seeing as it's stuck closed, that's proving to be difficult. I've used the search button but haven't found a solution, any suggestions?
Edit:
So far I'm at a loss. I tried pulling the fuse to no avail. I also took the inner door handle apart and tugged at the lock rod....but it wouldn't budge. I can't get to the front door panel screw, and I can't get enough leverage on the bottom of the door panel to pop it loose. Grr.
Old 04-07-2011, 04:22 PM
walternate's Avatar
Default Re: 96 Del Sol driver door won't unlock or open
Also, I just bought this car yesterday and had my first problem this morning
Still no progress, so I'll distract you all with a picture.
Old 04-07-2011, 04:37 PM
19crx93's Avatar
nice car how much did you get that for?
Old 04-07-2011, 04:41 PM
walternate's Avatar
We'll just say I got a stellar deal.
Old 04-07-2011, 04:46 PM
19crx93's Avatar
did you try pb blaster. or a screw driver to try the acctual latch?
Old 04-07-2011, 04:57 PM
walternate's Avatar
Can't get to the latch with the door shut
Old 04-07-2011, 05:25 PM
drtysohc's Avatar
so weak. We'll figure it out, GF.
Old 04-07-2011, 06:52 PM
walternate's Avatar
Here's to hoping..
Old 04-08-2011, 04:19 AM
walternate's Avatar
Bump for help
Old 04-08-2011, 08:11 AM
BigDaddyVtec895's Avatar
im thinkiing ur having this problem because this car may have been hit before nd the hing or the latch may be bent also try rolling the window downn nd pushing or jumping down on the door nd see the results
Old 04-08-2011, 08:53 AM
Sonia's Driver's Avatar
It sounds like the actuator is seized.
Where are the buttons that control the power locks? (I have an S - manual locks)
Is the rod stuck rigidly in place, or does it move to the lock/unlock position with no effect?
Have you tried pulling on the rod and activating the power locks at the same time?
What happems when you put your key in the lock and try to turn? If the key won't turn, what happens when you try to turn the key and activate the power locks at the same time? Also pulling on the rod at the same time?
One of the cheaper fixes might be to call a tow truck that can use a slimjim to unlock - make sure that you explain the problem up front - you need someone with a bunch of experience. Perhaps direct pressure will overcome the actuator.
A backup for that: cut the door card so that you can get to the actusator and lock mechanism yourself.
Good Luck!
Old 04-08-2011, 02:57 PM
accrdwgnguy's Avatar
Having this same issue with my 95 DX 4dr, the driver latch seized up 2 days before I was going to sell the thing! Convinced this car is cursed.
Anyways I can lock and unlock the door, but both inner and outer handles act like its locked. Was gonna try using a coat hanger wire, but the slim jim maybe a better choice.
Someone else must have had this problem. I have another junk door with a working latch i can swap out, just need to get the door open.
Old 04-11-2011, 08:20 AM
Ethanc's Avatar
Did you try the slim jim method? What happens if trying to unlock it by key?
Old 04-11-2011, 09:12 AM
lunareg's Avatar
I cant help but mention the dukes of hazard here..
but on a serious note, thats sucks, It sounds like an accident to me.
Old 04-11-2011, 09:47 AM
Deuce1's Avatar
I agree with Sonia's Driver. The actuator being seized is most likely the issue. The same thing happened to my 98 Civic EX. I could turn the lock both ways with the key but the door would not budge. I eventually got the door panel off while the door was still closed. It is possible, but damage might ensue. I then got an air hammer and chisel and blasted away at the actuator. Door eventually popped open, and I then replaced the actuator.
Old 04-11-2011, 12:02 PM
DelSolid21's Avatar
I have the same problem. Been getting in through the passenger side for 3 weeks.
Old 04-13-2011, 04:24 PM
walternate's Avatar
Got the problem resolved everyone.
Turns out it was a spring that popped off in conjunction with a plastic piece that jammed inside. Released the plastic piece and managed to get the door to open, then proceeded to pop the panel off and retrieved then replaced the spring.
Thanks to all!
doklo
04-06-2021 03:54 PM
tuvtec
10-08-2014 12:01 AM
marcelosm
10
07-28-2014 05:45 PM
Superchick9235
01-27-2012 01:28 PM
toben
02-24-2007 08:05 PM
Quick Reply: 96 Del Sol driver door won't unlock or open
