96 civic stalls when you hit the gas pedal - Honda-Tech
Old 04-24-2012, 08:23 PM   #1
Default 96 civic stalls when you hit the gas pedal
I just picked up a 96 civic for cheap. It starts and runs (idle goes up and down a little) but when you press the gas pedal it stalls. If you let up it will fire again and resume idling. If you keep it pressed it will eventually die. However if you just slowly push the pedal down it will actually rev up. I cant figure out where to go with this. My first time working on a honda or any foreign car. I know the car has the 1.6l and it has an aftermarket intake manifold and header(which i guess eliminated the cat) and downpipe. I replaced the 02 sensor on the downpipe because the wires had been cut then spliced back together. I noticed it when i looked at the car and i figured that was surely the problem and thought i could pick the car up cheap and fix it cheap! But its still doing it. Any suggestions would be greatly appreciated! thanks
gibzilla is offline   Reply With Quote
Old 04-24-2012, 09:23 PM   #2
Default Re: 96 civic stalls when you hit the gas pedal
Check engine light?? I would start with checking the tps sensor for damage or being adjusted out of spec.
Nickeg9Ej1 is offline   Reply With Quote
Old 04-24-2012, 10:43 PM   #3
bigginsUT's Avatar
possibly the fuel pump. that's what would happen to mine when it went out. at least you got it for cheap - fix it and she's good!
oh - troubleshoot that first
bigginsUT is offline   Reply With Quote
Old 04-25-2012, 02:34 AM   #4
Technical Hero
HondaPartsHero's Avatar
Done any maintenance? Tune up?
HondaPartsHero is offline   Reply With Quote
Old 04-25-2012, 07:10 AM   #5
I was thinking the tps too. but how do you test/adjust that? It really dosent seem like the fuel pump but im gonna put a pressure tester on it today to be sure. I havent done anything else, I just got the car a couple of days ago. I know this is something simple and when i get it fixed I either got a good mpg car for going to and from work or I can sell it and turn a quick profit. The car is in pretty good shape.
Old 04-25-2012, 07:41 AM   #6
Old 04-25-2012, 08:37 AM   #7
well now i feel stupid for asking how to check the tps without looking first. but thanks Nick. I'm going to go check that right now.
Old 04-25-2012, 09:51 AM   #8
Thank you Nickeg9Ej1! The link you posted lead me straight to the problem. The MAP and TPS connectors were switched. I swapped them back to the correct plug and reset the computer and it runs correctly now. Thank you so much!
Old 04-25-2012, 10:31 AM   #9
No problem
2001 Civic LX Stalling Craig Duni Honda Civic (2001 - 2005) 0 12-06-2015 02:39 PM
93 del sol - idles low and stalls or won't start without pushing down the gas pedal fastfwd Honda Civic / Del Sol (1992 - 2000) 10 09-29-2010 01:52 PM
97 Passport, hard starting, stalling, rough idle until warm happy123 Odyssey | Ridgeline | MDX | Pilot | RDX | HR-V 3 05-21-2009 04:11 PM
please this accord needs help boyracers Honda Accord (1990 - 2002) 2 11-26-2003 04:21 PM
doyou guys think this is a big problem? boyracers General Discussion and Debate 1 11-26-2003 09:03 AM
Tags
96, applygas, car, civic, dies, gas, hit, honda, idles, pedal, press, problems, push, stalls, stumbles, tech
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
