96 civic fuel pump priming on/off
Old 05-21-2013, 08:32 PM
red99tegra's Avatar
Default 96 civic fuel pump priming on/off
im having trouble with my civic.. the fuel pump primes on and off.. sometimes it will prime right away sometimes take 2 minutes or more.
When I turn the key on the check engine light stays on until the pump primes however long that is. I already swapped out the main relay with a new one and same thing happened so I put the old one in.
I found some cut wires coming from my ignition switch? anyone know what they are for?
got 3 pics.. see of they load
Old 05-21-2013, 08:35 PM
red99tegra's Avatar
Default Re: 96 civic fuel pump priming on/off
red/black and white/blue from first pic attached to the black clip, pic is upside down sorry
last pic white/green go to the black sensor looking thing ontop of switch
Old 05-22-2013, 01:00 PM
Former User's Avatar
Stock 96 Civic? Any mods?
The ECU may be going bad.
Also try replacing fuses 44 and 13, as well as cleaning/tightening the G101 ground on the thermostat housing.
Some electrical tests could also be done, if you're able and willing.
Old 05-22-2013, 03:47 PM
red99tegra's Avatar
yea all stock honda.. i will check that ground and fuses
Old 05-22-2013, 05:26 PM
red99tegra's Avatar
the ground spot had corrosion around it, cleaned it and added a wire from that point to a ground near the trans. car started about ten or so times in a row.. will check it out again later
cdmed6si
04-09-2013 08:08 PM
withouttrouble
03-21-2012 08:08 PM
fusion645
Audio / Security / Video
05-09-2011 04:48 PM
Destructive-
31
02-27-2011 12:59 PM
dj-t
10-07-2007 08:36 PM
Quick Reply: 96 civic fuel pump priming on/off
