What type of oil?
What type of oil?
i have a d16y8 with 104xxx milles, i always put regular oil on it 10w 40, is that good for my engine, i do the change every 2500milles, wich oil is best for keep it safe and runing good?
Re: What type of oil?
Always depends on your preference, and weather but 5w - 30 is ideal for a Honda engine and most usually say Castrol. High mileage is also good for where you're at.
MiG-21 superfan
2500 miles? why? either follow the factory recommendations as per the manual if you are going to run conventional oil (like pennzoil yellow bottle), or get a used oil analysis (for either conventional or if you want your money's worth with synthetic). otherwise you are wasting oil for nothing. no reason.
as far as weight, the owner's manual will give you detailed recommendations, usually dictated by ambient temperature, and the oil cap will give you the best middle-of-the-road suggestion.
http://www.bobistheoilguy.com/forums/ubbthreads.php - anything you could possibly ever want to know about oil
http://www.blackstone-labs.com/ - where i get my used oil analysis so i don't waste oil and time
good luck!
good luck!
I can tell you what oil not to use and that is Mobil 1, unless you want to rebuild your motor.
I use Mobil 1 in everything I own..I am with everyone else, I'd like to know why it will make you have to rebuild your motor. I have 240k miles on my Ford Explorer with a 5.0L V8 and its AWD so I am a strong fan / supporter of Mobil 1.
jbsmith
07-06-2004 04:44 PM
tensai717
12-09-2001 03:49 PM
