96 Civic auto has a transmission CEL code and hard shifting problem
Old 11-29-2010, 08:47 PM
H_civic_H's Avatar
Default 96 Civic auto has a transmission CEL code and hard shifting problem
I'm having trouble with my civic 96.. its automatic and it shifting really hard. I scanned it and it said it was the turbine speed sensor but honda dealership doesn't even know what that is... When I put my car in drive it shifts hard so could some one help me???
Old 11-29-2010, 08:55 PM
Former User's Avatar
Default Re: Help me!!!!
Thread titles MUST be subject specific so that members browsing topics can easily understand the tech problem without reading the post:
https://honda-tech.com/forums/showpo...12&postcount=1
Please familiarize yourself with the stickies at the top.
Because you are a new member, I edited the title for you this time.
Post the specific CEL code.
Old 11-29-2010, 09:09 PM
H_civic_H's Avatar
Default Re: 96 Civic auto has a transmission CEL code and hard shifting problem
Thank you do you think it has something to do with my transmission? or my sensors?
Old 11-29-2010, 09:11 PM
H_civic_H's Avatar
p0715 "turbine input shaft speed sensor circuit
Old 11-29-2010, 09:13 PM
If you have a transmission trouble code, then it may be a sensor or electrical problem. The first step is for you to post the specific CEL code.
Old 11-29-2010, 09:16 PM
H_civic_H's Avatar
thats the only code that it gave me and my D4 light is flashing?
Old 11-29-2010, 09:22 PM
Old 11-29-2010, 09:32 PM
H_civic_H's Avatar
Thanks man
Old 11-30-2010, 06:09 AM
Seagull Management
94EG8's Avatar
I had the same issue, super hard shifting and a CEL for P0715, Sensor was fine, wiring was fine. Ended up replacing the transmission, still get an intermittent CEL for P0715 but the shifting is normal now. I'm thinking I should have replaced the torque converter as well.
Old 11-30-2010, 04:18 PM
H_civic_H's Avatar
Did your D4 light flash with da old tranny ???
Old 11-30-2010, 04:50 PM
Seagull Management
94EG8's Avatar
Not that I was aware of, it's mom's car I almost never drive it. I really only drove it to determine that there was in fact something wrong with it. Right before we swapped the tranny it was doing some really funky shifting if you tried to keep a steady 30 - 40mph speed. I ended up picking up a used tranny for $100 and put new axle seals and a new mainshaft seal in it and swapped it in. Put fresh honda Z1 fluid in it and worked great for close to a month, then the CEL came on again, P0715 (same code it had before), cleared code with scan tool, reappeared about 2 weeks later, cleared again, returned about a week later. Didn't even bother to clear it that time (everytime the ECU does the initial relearn the mileage is crap so I figured i'd just leave it alone) light went out on its own a week or 2 later, checked with scan tool, still have stored code, didn't clear it, a couple of weeks later light comes on, stayed on for a week or so, then went out again, I think its been out for over a month now, but still shows a stored code. Whats really weird is that it shifts fine I'm still not sure exactly what the problem is, but i'm starting think either the torque converter is starting to go bad or the fact that I used a Y8 automatic has something to do with it.
Old 11-30-2010, 05:04 PM
H_civic_H's Avatar
Oh yea my D4 flashes.... i might just drive it till my tranny blows n then get a new one.
Old 11-30-2010, 05:09 PM
Does the D4 light blink only when the service connector is jumped or also when it is not?
Old 11-30-2010, 08:09 PM
H_civic_H's Avatar
It flashes 24 7 wen i turn the key
Old 11-30-2010, 08:13 PM
Hmmm...as you can possibly see in the diagram I posted, P0715 should not cause the D4 light to blink (OFF for 96-97 Civics), of course unless the service connector is jumped.
When you jump the service connector, does the D4 light blink other codes in addition to code 15 (=P0715)?
Old 12-01-2010, 09:14 PM
H_civic_H's Avatar
what do you mean by jumped??
Old 12-01-2010, 09:47 PM
ifIexplode's Avatar
Damn thats good info, Ive been looking for auto trans codes for awhile.
Old 12-02-2010, 03:39 AM
The connector is shorted with a jumper wire.
Old 12-02-2010, 09:53 PM
H_civic_H's Avatar
i havent jumped it n i swapped my engine n my old engine didnt make the d4 light blink
theprofiteer
17
01-10-2019 09:35 AM
ce1 boy
01-02-2016 08:42 AM
ce1 boy
Transmission & Drivetrain
11-29-2012 06:53 PM
Sic_DA_Nine
11-04-2007 06:19 PM
Carson89X
02-18-2005 09:06 AM
Quick Reply: 96 Civic auto has a transmission CEL code and hard shifting problem
