95 Honda Civic. Inner Tie Rod. Now replacing the Steering boot. Where can I get them? - Honda-Tech
Old 01-18-2011, 11:00 AM   #1
abcdefg123's Avatar
Default 95 Honda Civic. Inner Tie Rod. Now replacing the Steering boot. Where can I get them?
Hello, I'm looking for the steering boots that cover the inner tie rod for my 95 Civic EX Coupe. I'm looking to pick them up today or have them by the morning so I was wondering where I can get them? Advance Auto has these: http://shop.advanceautoparts.com/web...___#fragment-1 but it says only one is required but both sides have them. Thanks for any help.
abcdefg123 is offline   Reply With Quote
Old 01-18-2011, 11:05 AM   #2
99blackEM1's Avatar
Default Re: 95 Honda Civic. Inner Tie Rod. Now replacing the Steering boot. Where can I get t
I believe they mean 1 per side.
99blackEM1 is offline   Reply With Quote
Old 01-18-2011, 11:09 AM   #3
abcdefg123's Avatar
That's what I thought originally but there is not RH option listed either.
Old 01-18-2011, 11:16 AM   #4
abcdefg123's Avatar
I guess just order two of the same one, It would work either way but I was just concerned.
Old 01-18-2011, 11:29 AM   #5
abcdefg123's Avatar
Can anyone verify those are the actual ones I need for my car? and for both sides? Also if I removed the inner rod but lined it up properly would it ruin the alignment at all?
Old 01-18-2011, 01:29 PM   #6
96hb's Avatar
I had to get mine from Napa. They were friggin' expensive too. Like $50 for the pair!
96hb is offline   Reply With Quote
Old 01-18-2011, 05:05 PM   #7
TwoFaced's Avatar
If you're patient I'm sure you can find them online for waaaaaaaay cheaper...I understand patience isn't always a luxury afforded to us with these things.
TwoFaced is offline   Reply With Quote
Old 01-19-2011, 07:09 AM   #8
They're available at the dealer for cheaper than anywhere else.
$18 each IIRC...
The ones I got at Autozone 8 months ago haven't held up very well...
hondapartsnow.com has worked pretty well for me when I need OEM parts, but can wait a week.
Sonia's Driver is offline   Reply With Quote
Old 01-19-2011, 07:28 AM   #9
Got mine at Advance. Seemed to be ok so far.
If you carefully count the threads on the tie rod you shouldn't mess up your alignment....much...
Hardest part for me was getting the ball joint out. Couldn't even get the castle nut off because it just spins with the joint. I think maybe you can lower the car down to put pressure on it.
andyz is offline   Reply With Quote
Old 01-19-2011, 07:41 AM   #10
speedooo's Avatar
OEM
speedooo is offline   Reply With Quote
Torn steering dust cover, no leak. dgdarien Honda Civic / Del Sol (1992 - 2000) 22 11-18-2016 11:19 AM
92 honda civic dx eg driver side steering boot bellow Hondaciv866 Honda Civic / Del Sol (1992 - 2000) 6 07-17-2015 04:48 PM
1994 civic hatch wobble? tundra2000 Honda Civic / Del Sol (1992 - 2000) 2 05-27-2011 10:17 AM
1995 Integra Inner Tie-rod Oo0MaRkY0oO Acura Integra 5 05-14-2008 10:01 AM
inner tie rod/boot grease question Killersohc Tech / Misc 1 06-02-2006 02:16 PM
Tags
1999, 95, 97, advance, auto, boot, changing, civic, honda, rod, rods, tie, tierod, tool, tools
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
