95 civic vtech issue
I have a 95 civic dx i did a d16z6 head and intake swap to my civic with d15b block i have a p28 ecu i have vtech wired to ecu everything is pluged in right 100% but my vtech is not kicking on at all i got new vtech solenoid switch checked wires again still nothing i also sliced in a light to the a4 ecu wire and see if vtech is kicking on or if it getting power light dont even come on can someone help me out please
Re: 95 civic vtech issue
Well when I get on it hard to see if vtec is working I get cell 22 but if I turn the car off and key back on only cell light gose away .. I replaced vtec over and over again I wired a light from the ecu wires that go to the vtec to see if light will come on when the vtec should kick on but nothing there .. I also checked vtec wires from ecu to vtec everything is correct .. Oil pressure is fine as well .. I don't know where to go from here other then to ask maybe someone has useful information that can lead me to success .. Thank you !!
I wired in a light into one of the wires that come out of the ecu for the vtec to see if the vtec was kicking on and the light never came on at all .. I replaced vtec same thing I wonder if the wires are bad or the p28 ecu vtec part is bad but my brother took it into honda shop and they wired vtec in the ecu and replaced ecu as well so I don't know where the problem is !!
Re: 95 civic vtec issue
Do you think that the distributer can cause this issue because I have 1.6 head and intake but I never changed the distributer I have one for a on there for a 1.5 vtec and as well as I never changed spark plugs
It should be 2 plugs 9 pins correct !! Reason why I ask is because for whatever reason I can't get the vtec to work I have done every test there is reset the ecu replaced vtec and I still get cell light 21 and 22 I have checked oil pressure I have read lots or google and forums tryed everything and still no luck so if some could help me figure this out please I want to feel that little more power I love my honda
If you want to feel power, you should've swapped your motor lol. Anyways, code 22 is your vtec oil pressure switch. Double check your wiring. It's likely the reason.
possibly a fault/short in the electrical. run a multimeter to test for continuity from the switch to the ecu. if thats good, test continuity from the switch to the chassis (ground). if theres continuity there, that may be your problem.
It's best if you get a manual as well. Helps a lot.
Damn !! Everything's good but when I get the cell light the car runs better it's crazy **** tho .. But anyhow anyone live in the portland oregon area or hillsboro oregon area that know way more then me I have done everything tryed everything having no luck
That link is not working but could this be an issue with all this My car acts like it dose not have a rev limiter it will max a tach to the fullest and when I drive it it gose to 5000 rpm' s and then skips to 7000 and maxes out to 10000 rpms it's crazy but it's what it dose
Sounds like you wired some stuff up wrong buddy. You should go over all the wiring you changed/added and make sure that any splices or connections are secure and well insulated and start testing for continuity to make sure there's no breaks and the wire is still in one piece from start to finish
I have checked everything nothing changes well I install car systems and alarms kill switches all kinds of wireing so I'm know to triple check
My work ..? But any how I would like to know how much psi can u put to a d16z6 mini mi swap because I want to put a turbo in there .. With out changing anything .. And I start my car I know my oil light stays on for a 1 then shuts off so I'm thinking of replacing the oil putative thats my vtec issue ?
rotascircuit
09-28-2007 05:59 PM
Suck my DX
05-02-2007 11:42 AM
