95 civic idling up and down... - Honda-Tech
Old 11-22-2009, 11:14 AM   #1
sins's Avatar
Icon3 95 civic idling up and down...
Ok so I just put on a obx intake manifold I purchased for my 95 civic d15b. I connected everything how it should go but then when I went to start it up the car just kept idling up and down. I replaced all old hoses with new hoses so I wouldn't have any vaccum leaks. Help me out honda-tech members.
sins is offline   Reply With Quote
Old 11-22-2009, 11:34 AM   #2
sins's Avatar
Default Re: 95 civic idling up and down...
Can it be that since this new intake manifold is bigger than the stock one, its holding more air therefore something is not reading right or have to adjust something
Old 11-22-2009, 11:53 AM   #3
Check your throttle cable adjustment.
E.Honda is offline   Reply With Quote
Old 11-22-2009, 12:33 PM   #4
sins's Avatar
Quote:
I did its good
Old 11-22-2009, 02:39 PM   #5
thecruzs2007@yahoo.com's Avatar
maybe a vacum leak or any leak of some sort..check it throughly
thecruzs2007@yahoo.com is offline   Reply With Quote
Old 11-22-2009, 02:52 PM   #6
Matt93eg's Avatar
I would also check and Clean the IACV(Idle Air Control Valve). If its doing it when cold as well I would check and Clean the FITV(Fast Idle Thermo Valve). The IACV is on the back of the Plenum on the Intake Manifold. FITV is on the bottom of the Throttle Body. Any CEL?
Matt93eg is offline   Reply With Quote
Old 11-22-2009, 02:59 PM   #7
HCivExoo's Avatar
you have a vacuum leak somewhere. make sure you don't have a leak in the gasket itself. you can check this with a bottle of carb cleaner. spray it around the gasket while the motor is running if it stumbles then you found it. also don't forget your TB gasket as well.
HCivExoo is offline   Reply With Quote
Old 11-24-2009, 08:21 PM   #8
sins's Avatar
Quote:
ok ill check tomorrow
Old 11-24-2009, 10:18 PM   #9
itsnotfast's Avatar
He's right but be careful not to spray your alternater as it could pretty much blow up.
itsnotfast is offline   Reply With Quote
Old 11-25-2009, 03:36 AM   #10
sins's Avatar
Quote:
thanks for the info, ill be super careful
Old 11-25-2009, 05:30 AM   #11
Autointeg's Avatar
any cels?
Autointeg is offline   Reply With Quote
Old 11-25-2009, 04:20 PM   #12
97sol's Avatar
im a noob so i was wondering what does the throttle cable have anything to do with the idle being rough?
97sol is offline   Reply With Quote
Old 11-25-2009, 06:19 PM   #13
i just swapped a y8 intake manifold onto my y7 and im having the same problem, the motor starts an sits as 1500 as usual, then as it warms the idle starts bouncing from 1500 to 750 and back up constantly and wont stop. all hoses are new, i cleaned the thing that bolts to the bottom of the throttle body(dont know name) has two hoses and an electrical connection, what else is there to clean and check?
supermansdx is offline   Reply With Quote
Old 11-25-2009, 07:48 PM   #14
97sol's Avatar
Quote:
i just finished mine yesterday and had the same prob. the thing on the bottom is the iacv but anyway what happened to me was that the o-ring under the map sensor wasn't sitting correct and also the studs and bolts were leaking for some odd reason so i put a little thread sealer on the studs and bolts and that fixed my idle. i hope this helps you cuz i was almost ready to put my y7 im back on!
Old 11-25-2009, 08:29 PM   #15
itsnotfast's Avatar
Quote:
Nope.
Old 11-26-2009, 07:16 AM   #16
97sol's Avatar
hey i also forgot make sure you are using the y7 tb gasket because the y8 tb gasket is too short and doesn't go around the iacv so id say that this is prolly what is wrong in your case.
Old 11-26-2009, 02:00 PM   #17
got any pictures?
Old 11-26-2009, 03:01 PM   #18
P4X
GOT THE SAME PROBLEM AND RESOLVED IT, THE PROBLEM IS IN THE TB GASKET, MAKE SURE TO USE (ON A Y7 TO Y8 SWAP) THE Y7 TB GASKET AND MAKE SURE TO PUT IT IN THE RIGHT PLACE, THERE IS A LITTLE VACUUM LINE THAT REACH THE MAP SENSOR THAT IF NOT RECEIVE THE VACUUM MAKE THE IDLE GOING FROM 1000 TO 2500 UP AND DOWN... THIS WAS MY PROBLEM... IF THE PROBLEM PERSIST IS FOR SURE A VACUUM LEAK SOMEWHERE...
Hope to be helpfull...
Andrea...
P4X is offline   Reply With Quote
Old 11-26-2009, 03:24 PM   #19
97sol's Avatar
got any pictures?
just use the gasket that came off your car originally and not the one with the new intake
Old 11-26-2009, 06:11 PM   #20
tico's Avatar
If you didn't make sure that gaskets were sitting wrong or the o-Rings are torn or damaged then it will definatley will have a crazy idle. IMO I would take everything back off and inspect all the gaskets and make sure that they are ok. If everything is ok thenu need to adjust your IACV by honda procedures. That new intake has a larger chamber and draws in more air. You need to re calibrate ur ECM to compensate for the new air flow.
tico is offline   Reply With Quote
Old 11-26-2009, 06:20 PM   #21
97sol's Avatar
Quote:
how do you calibrate the ecm?
Old 11-27-2009, 09:59 AM   #22
tico's Avatar
well after u verify that the gaskets and orings are good. here is step by step
1. start engine. No loads(lights radio ect....)
2. let warm up i.e. fan comes on
3.disconnect IACV
4. adjust idle screw on TB til idle is at 470 rpm (+- 50rpm)
5. shut off engine
6. reconnect IACV
7. remove ECU fuse for 25 seconds
8. re instal fuse
9. start engine let idle no loads for 1 minute
10. turn on hi beams verify idle stabilizes
if it all checks out then your good.. if idle drops low then u will need to raise the idle up a bit.. but u have to start from the begining
Old 11-27-2009, 11:56 AM   #23
itsnotfast's Avatar
Ok, this is a fairly common problem when you take the i/m apart. Usually it's nothing more than a vacuum leak. It could be that something didn't line up right or the i/m you put on was warped/bent or even scratched or cracked. Gaskets can look fine somethimes and have a hairline crack and cause this. So to pin point the problem you have two chioces: You can try to clean out the IAC valve or THOROUGHLY spray the whole intake manifold, the throttle body, the iac valve, and all vacuum lines with brake clean or some sort of carb cleaner. If your normally surging idle raises and stays high for a longer period of time than your car normally does you have found your leak. I highly doube this problem would be electronic.
Old 11-30-2009, 09:36 AM   #24
tico's Avatar
u might also want to check ur tps.. make sure i didnt get damaged in the swap.
Old 11-30-2009, 06:45 PM   #25
Hello fairly new to site and although i do not have a civic i was running into a similar problem. My problem is that every time i go to give the car gas the engine wants to die on me, whats awkward is that when the car is parked the idle seems to be fine. Can anyone give some insight?
dr0b0t_13 is offline   Reply With Quote
95 Civic Ej1 B16A1 swapped idles at 1500-2000rpm jtwarrior14 Hybrid / Engine Swaps 3 03-17-2015 01:40 PM
Vaccum leaking car stalling .. Brake booster?? acuralovar Acura Integra 21 04-13-2014 10:02 AM
One of my IACV hoses is cut Choppin Honda Civic / Del Sol (1992 - 2000) 3 03-02-2011 10:37 PM
Rough idle and sluggish aceleration preludequestion Honda Civic / Del Sol (1992 - 2000) 4 10-19-2009 12:41 PM
Idle Issues with GSR in EK w/Type R Intake Mani. IIXtremeHansen Hybrid / Engine Swaps 1 12-03-2007 12:31 PM
Tags
94, 95, 96, 97, acura, adjust, civic, cleaning, iac, idles, idling, integra, leak, leaks, steps, transmission, vacum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
