EK4 engine won't crank but push starts
Old 10-23-2010, 01:43 PM
darkside_vtec's Avatar
Default EK4 engine won't crank but push starts
Hi there
Having a problem starting my car.
Removed the battery today to remove the front camber control arms, but the battery back in and then car would not start.
Swapped the starter motor out for another one still nothing.
Checked all the fuses and relays, all fine apart from the interior light fuse
The car starts when push started.
When you go to crank the engine, the start motor clicks then the radiator fan comes on
Any ideas what is going on here?
Old 10-23-2010, 03:02 PM
Former User's Avatar
Default Re: EK4 starting problem
Check the transmission ground wire.
Old 10-24-2010, 01:42 AM
Any idea why the fan is coming on?
Old 10-24-2010, 03:43 AM
ken9's Avatar
Might be some wires connection problem.. Electrical isn't eazy to trouble shoot..
Old 10-24-2010, 05:50 AM
This would happen if someone has shorted the 2P connector of the radiator fan switch.
emilio2488
Honda Civic (2006 - 2015)
06-13-2014 06:30 AM
dwashy21
11-15-2013 04:16 PM
jonina
04-01-2013 08:01 PM
ChiDubysLS-VTEC
04-18-2009 04:36 PM
CDN Yellow ITR
09-02-2003 02:27 AM
Quick Reply: EK4 engine won't crank but push starts
